Prove that sequence is monotonic
  • Thread starter Thread starter Siune
    Sequence
The discussion focuses on proving that the sequence defined by \(\frac{1}{n^2}+\frac{(-1)^{n}}{3^n}\) is monotonic and decreasing. The user struggles to establish the inequality \(a_{n+1} - a_{n} \leq 0\) and ends up with a complex expression that complicates their proof. Additionally, they inquire about determining the limit of a sequence and how to identify if it is bounded, mentioning a specific example where they initially miscalculated terms. A response suggests that limits can sometimes be calculated directly from recurrence relations, providing a method for more complex sequences. The conversation highlights the challenges of proving monotonicity and understanding sequence behavior.
Siune
Need to prove that the following sequence is monotonic ( decreasing ).
I have idea how to prove that the sequence is decreasing that is:
a_{n+1} - a_{n} ≤ 0
but in this case, I can't get the inequality proved.
\frac{1}{(n+1)^2}+\frac{(-1)^{n+1}}{3^{n+1}} - \big( \frac{1}{n^2}+\frac{(-1)^{n}}{3^n} \big) ≤ 0
I end up in a mess, that looks like;
\frac{3^{n+1}(-2n-1)-2n^{2}(n+1)^2(-1)^n}{n^2((n+1)^2)3^{n+1}}
Could get any hint which way I should start to reform the equation?
Also I'm interested in other thing. If I need to show that for example this sequence is bounded, how I can "see" what the limit "might " be.
In every material I see, that they check the first few terms and make "good guess"?
For example we have sequence a_0 = 0, a_{n+1} = (1/2)x_n +5. We can see when calculating the first we values, that
it seems to converge to x = 10. But if the sequence is more complicated?
The 3th terms is 0.074074, the 4th term is 0.07484, greater. The sequence is not monotonous.
ehild
Ah, stupid me. Had calculated the first terms totally wrong.. Well, that could have saved some time and not bang my head against the wall! :D
Moderators can lock this up, sorry for inconvience.
a_{n+1} - a_{n} ≤ 0
To answer your second question: if ##a_{n+1} = (1/2)a_n + 5##, and IF ##a_n## has a limit ##L##, you can calculate ##L## from ##L = (1/2)L + 5##. In this case you can show that for any value of ##a_0## a limit does, indeed, exist. As for more complicated examples, sometimes the same type of 'trick' works (not always, but sometimes).
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
