MHB Does This Series Diverge Without Using the Limit Comparison Test?
  • Thread starter Thread starter VincentP
    Series
VincentP
I need to prove that
$$ \sum_{n=0}^{\infty} \left(\exp\left(\frac{n^2+2n}{n^2+1} \right) - e \right) $$
diverges. The solution suggests using the limit comparison test, but since we didn't
cover that in my class I was wondering if there is some other easy way to prove divergence.
Thank you for your help.
Vincent
I would suggest the direct comparison test with the harmonic series:
$$\sum_{n=1}^{\infty}\frac{1}{n}$$
which is known to diverge. If you can show that:
$$\frac{1}{n}\le\exp\left(\frac{n^2+2n}{n^2+1} \right)-e$$ where $$n\in\mathbb{N}$$
then you will have demonstrated that the series in question diverges. I would try showing that the $n$th term of the harmonic series converges more rapidly to zero than the given series.
Vincent
Is...
$$ e^{\frac{n^{2} + 2 n}{n^{2}+1}} - e = e\ (e^{\frac{2 n -1}{n^{2}+1}} - 1) > e\ \frac{2 n -1}{n^{2}+1}$$
... and the series...
$$ \sum_{n=0}^{\infty} \frac{2 n -1}{n^{2}+1}$$
... diverges...
Kind regards
$\chi$ $\sigma$
For original Zeta function, ζ(s)=1+1/2^s+1/3^s+1/4^s+... =1+e^(-slog2)+e^(-slog3)+e^(-slog4)+... , Re(s)>1 Riemann extended the Zeta function to the region where s≠1 using analytical extension. New Zeta function is in the form of contour integration, which appears simple but is actually more inconvenient to analyze than the original Zeta function. The original Zeta function already contains all the information about the distribution of prime numbers. So we only handle with original Zeta...
