Prove x^3 - y^3 = (x - y)(x^2 +xy + y^2)
  • Thread starter Thread starter zeion
The discussion centers on proving the identity x^3 - y^3 = (x - y)(x^2 + xy + y^2). Participants explore various methods, including polynomial division and geometric interpretations, while emphasizing the importance of understanding the properties of addition and multiplication. There's a debate about whether to expand the right-hand side, with some arguing it's unnecessary if one can derive factors through roots. The conversation also touches on the difficulty of applying these concepts to higher-degree polynomials and the value of intuitive versus formal mathematical approaches. Ultimately, the consensus leans towards using established algebraic techniques for clarity and accuracy in proofs.
zeion
Not sure.. I know I'm not supposed to expand the right side. lol.
Need to use some basic properties?
Why can't you expand the right side?
Do you know how to determine the roots of
x^3-1=0?
If so, can you use them to write down the roots of
x^3-y^3=0?
Uhh..
x^3 - 1 = 0 \Rightarrow x^3 = 1 \Rightarrow x = 1 ?
ok you obviously don't know complex numbers then, again, why can't you just expand the right side? Why did you say "I know I'm not supposed to expand the right side"?
zeion said:
Uhh..
That's only one root. Since it's a cubic equation there are three roots. If we ignore that for the moment, can you use the root x = 1 to write down a factor of (x3 - y3)? The remaining factor will be quadratic and there's a couple of ways you might find the coefficients.
Okay so one root is x = y
So (x - y) is a root.
(x - y) is a factor. The remaining factors give a quadratic form, any ideas on how to determine the coefficients?
Um long division?
An easier way to do this would be to expand the right hand side as mentallic suggested.
And i presume that since you don't know complex numbers this is probably the easiest way.
:smile:
zeion said:
Um long division?
Sure, if you know how to do that, it's a good way.
But is there a way to prove this using the properties of addition and multiplication?
You are using addition and multiplication. If the RHS wasn't given and you were asked to factor x3 - y3, then you would first find the roots. If you didn't know about roots of unity, you'd only be able to find the real root. This gives one factor, if you know how to divide polynomials, you can find the other factor by division.
Uhh, yeah! There is more than one way to prove something, but the easiest would still be to expand the right side :-p
Try it geometrically. First as a warmup, see if you can prove a2-b2=(a-b)(a+b) by drawing a big square of side length a with a small square of side length b inside it (the smaller square should share corners with the larger square).
What if the RHS wasn't given? Give the guy credit for wanting to learn how to actually learn how to compute something rather than just verify an answer.
The RHS can be shown by some simple factorizing of the form ab+ac=a(b+c). Try it yourself.
This isn't hard if you expand the RHS. x^3 + x^2y + xy^2 - x^2y - xy^2 - y^3 and the rest easy...
But the RHS was given. First answer the question asked, then add whatever other information you want. The difficulty here was clearly the statement "I know I'm not supposed to expand the right side. lol."
It sure was Hall, but I had a feeling that original poster didn't know that
if you have (a+b)(a+b)= a^2 + ab + ab + b^2
It hard to be young these days!
No, I think he knows how to expand since he's dealing with the difference of two cubes. He's more interested in how it works (besides applying the usual algebraic techniques) like fzero said.
For example in the last question it asked me to prove:
x^2 + y^2 = (x + y)(x - y)
So I did something like
x^2 + y^2 \Rightarrow x^2 + xy - xy + y^2 \Rightarrow x(x + y) - y(x + y) \Rightarrow (x + y)(x - y)
So I was just wondering how to do something similar with this one.
This is not true. However, x2 - y2 = (x - y)(x + y)
Use = for expressions that are equal, not \Rightarrow.
x2 + xy - xy + y2 = x(x + y) - y(x - y). Note that this is not equal to (x - y)(x + y).
zeion, you mean x2-y2=(x+y)(x-y)
Well, working backwards from (x+y)(x-y) you get x(x-y)+y(x-y)=x2-xy+xy-y2
For the difference of two cubes, x3-y3=(x-y)(x2+xy+y2) so again working backwards you get x(x2+xy+y2)-y(x2+xy+y2)
expanding,
x3+x2y+xy2-x2y-xy2-y3
So to factorize x3-y3 you would need to know that you have to add and subtract x2y and xy2 from the expression and factorize from there.
The geometric technique I mentioned helps you do this without having to guess, it quickly shows you what you must add and subtract in order to factorize the expression.
Ok I tried this on the cube:
So I want to take out a small cube b^3 from big cube a^3
I split the remaining cube into rectangle cubes and added the area:
a^3 - b^3 = (a - b)(a)(b) + (a - b)(b)(b) + (a - b)(a)(a) = (a - b)(a^2 + ab + b^2)
Is there a way to extend this to work for more than 3D?
What if a < b? lol?
I thought about that question too. It is possible to extend this idea by evaluating the properties of a 4-d shape but we can't draw it on paper in any reasonable way, so it would be venturing into a theoretical world again which won't be any more of a useful tool to prove it than expanding the factorized expression would be.
By the way, if it asked you in a book to prove the difference of two cubes, almost surely it expected you to just expand the right side, or possibly using polynomial division.
Here is a method that doesn't involve manipulating the right hand side, which is more I think of what we're looking for:
Artificially create a factor (x - y) and add canceling terms at the end:
x^3 - y^3 = (x - y)( x^2 ) + ( x - y )( y^2 ) + x^2 * y - y^2 * x
With the final two terms cancelling the terms on the right hand side that don't appear on the left hand side.
Then pull out another ( x - y ) on the final two terms:
x^2 * y - y^2 * x = ( x - y )( x * y )
Put it together and you're done!
This is an intuitively based response and I don't see it working for degrees higher than 3. You know where it's meant to lead to, so what if we asked you to try do this for x7+y7? Without knowing the pattern or ever having seen the second factor, it won't be an easy task to do. Polynomial division however is a mathematical process which doesn't require intuitive guesses.
