Proving Bounded Subsets of R are Totally Bounded
  • Thread starter Thread starter jdcasey9
    Bounded Subsets
jdcasey9
Prove that a bounded subset of R is totally bounded.
Fix E > 0. Let A be subset of R, x be contained in A, and B(E/2, a) where E/2 is the radius of the ball and a is the center.
Assume that B(E/2, a) is closed (since a similar open ball is contained in the closed one we can infer it is true as well). We can find balls around each x (contained in A) that can be described by B(E, x) (open or closed does not matter).
For B(E/2, a), we can always find d(x, a) <= E/2 < E...
I am having trouble describing the obvious assumption that the union of B(E, x)'s will contain (and more) all of B(E/2), do I need to use the triangle inequality? Or is a written explanation reason enough?
That doesn't make any sense at all. Are you sure you know what the definition of 'totally bounded' is? Isn't any bounded subset of R contained in an interval like [-M,M]?
For A subset in R I am trying to say that A is a subset of the union of balls that contain points in A (A=B(E/2, a) every other ball centered in A is B(E, x)). I have made the radiuses as such so that the Union of balls will always encompase every point in A. So, yes, every bounded subset of R is contained in an interval like [-M, M] (or (-M, M)), my bounded interval is the closed ball B(E/2, a)
The definition from notes for totally bounded:
(M,d) Fix E>0. A subset in M is an E-net if for all x is contained in M, there exists an a contained in A such that d(x, a)<E, equivalently, for all x contained in M, d(x,a)<E, equivalently, M is a subset of the Union of B(E,a). In words: "M is covered by E-balls".
That's the definition of E-net, not totally bounded. My definition says that M is totally bounded if for every e>0 there is a covering of M by a finite number of e-balls. Or, for every e>0 M contains a finite set A which is an e-net.
Ok. I'm understanding the difference between the two, but I am not understanding how that changes my prospective proof.
I guess I just don't understand what your proof is trying to do. On the other hand it's pretty easy to show directly that the interval [-M,M] can be covered with a finite number of balls of radius e, no matter how small e is.
Ok. So,
Fix E > 0. Let A = [-M, M] which is contained in R and let x=supA, y=infA. For any E, we know that x+E, y-E are outside of our interval and x-E, y+E are inside our interval. So to find the finitely many E-balls that cover [-M, M] would we just take any points M/2, -M/2 such that balls around them cover the entire interval and more? Like defining their radius to each be half of the interval?
jdcasey9 said:
Ok. So,
You can't pick the radius of your balls, they have to be E. Suppose A is contained in [-M,M]. Then if you cover [-M,M] you cover A. To cover [-M,M] just pick the center of the balls to be -M, -M+E/2, -M+2*(E/2), -M+3*(E/2), ... How many do you need?
We need enough so that the last one is centered around M. So if we continued in our pattern: -M, -M+E/2, -M+2*(E/2), -M+3*(E/2), ..., -M+2M would be last point, right? So we would need 4m/E points? (because x*(E/2) = 2M)
More or less, yes. E might not divide evenly into M, but the exact count isn't important. What's important is that you can clearly cover any finite interval with a finite number of balls of size E.
Ok, so to prove that a bounded subset of R is totally bounded:
Let E>0. Take A, a subset of [-M, M]. We can find finitely many balls such that their union covers [-M, M] by taking the balls B[E, -M], B[E, -M + E/2], B[E, -M + E], B[E, -M + 3E/2],..., B[E, M - E/2], B[E, M] (where E is the radius and the other is the center). Therefore, we have found a finite E-net that covers the interval [-M, M] and therefore covers A. So a bounded subset of R is totally bounded.
Is that sufficient enough?
It expresses the idea well enough. If you want to make it a little neater you can also choose M to be a even multiple of E/2.
Ok, but I just want to make sure that this is considered a sufficient proof for this problem. Nothing needs to be done more explicitly?
