Proving Complex Number Equality
To prove that the product (x - a)(x - b)(x - c)... of complex numbers results in a complex number, one must consider the nature of the roots. If the coefficients are real and one root is complex (x + iY), its conjugate (x - iY) must also be a root. The discussion highlights that for the product to yield a real result, specific conditions must be met, such as b = -d and a = c. The challenge lies in extending this proof to multiple factors, ensuring that no conjugate pairs are present. Ultimately, the assertion is that without conjugate pairs, the result remains complex.
Werg22
How to proove that
If a, b, c... are complex numbers, and none is conjugent to another the result will always be complex? Complex as is not real for those who like to complicate things...
Mathematics news on Phys.org
Werg22 said:
How to proove that
well, to start off, the first thing you need to do is to start it on your own.
Well, if the equation's coefficients are not complex, but x+iY is a root, then x-iY is also a root, since we collect imaginary parts separate from real.
well what do you get when you multiple one C:P(x) to a R:P(x)
Well this the only thing i could proove; with two factors;
(x - (a + bi))(x - (c + di))
x^2 - x(a + bi + c+di) + (c+di)(a+bi)
x?2 -x(a+c + i(b+d)) + (ca -bd + i(da + cb))
In order for the result to be real;
b = -d
-da = cb
ba=cb
a=c
so it is actually
(x - (a + bi))(x - (a -bi)), otherwise the result is not real. But how to proove that it is also applicable for any amount of factors?
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
10K
