Proving F=-constant*(delta y) for delta y < d
  • Context: MHB
  • Thread starter Thread starter Mango12
    Delta
The discussion revolves around proving the relationship F = -constant * (delta y) for the case where delta y is less than d. Participants explore the forces acting on a system involving charges and tensions, seeking to understand how these relate to the proposed equation.
  • Some participants describe the forces acting on a white ball, including weight, tension, and electric force, and suggest that the sum of these forces must equal zero for stability.
  • One participant expresses uncertainty about the angle theta and its relation to delta y, questioning how these variables interact in the context of the problem.
  • Another participant proposes using Newton's second law to set up equations for the forces in both x and y directions, indicating that the electric force can be expressed as F = k * q^2 / d^2.
  • There is a suggestion to derive the tension T from the y-direction force equation and substitute it into the x-direction equation to relate d and theta.
  • One participant mentions needing to demonstrate that a negative charge would oscillate as if on a spring, linking this behavior to the desired equation F = -constant * delta y.
  • A participant references a class discussion about making a substitution in the equations but expresses confusion about where this should occur.
Participants do not appear to reach a consensus on how to approach the proof or the specific relationships between the variables involved. Multiple competing views and uncertainties remain throughout the discussion.
Participants express confusion regarding the angle theta and its implications for the forces involved. There are also unresolved mathematical steps related to the substitution mentioned in class.
Mango12
I need to prove that F=-constant*(delta y) if delta y < d
I have no idea how to go about this. Please help!
Mathematics news on Phys.org
Look at one of the white balls. There are three forces acting on it: 1) the weight, 2) the tension, and last but not least, 3) the electric force. If the system is stable then the sum of these forces is 0 N.
Can you finish from there or do you need more detail?
-Dan
-Dan
well I think weight is mgsin(theta) and tension is Fesin(theta) + mgcos(theta)
But I don't know theta and I don't get what delta y has to do with it
I didn't notice this last night...What force are you trying to find?
Either way you are likely to have to consider at least some of the following...
Consider the charge on the right. The electric force between two point charges is [math]F = \frac{k q^2}{d^2}[/math]. The weight of the ball is mg, and you have a tension force,T, acting up and to the left at an angle [math]\theta[/math]. Using the usual xy coordinate system we have Newton's 2nd:
[math]\sum F_x = -T~cos( \theta ) + \frac{kq^2}{d^2} = 0 [/math]
[math]\sum F_y = T~sin( \theta ) - mg = 0[/math]
Use the y equation to get an equation for T. Put that T value into the x equation. That will get you an equation for d in terms of [math]\theta[/math]. Beyond that I don't know what force you are trying to calculate.
-Dan
-Dan
I'm not sure. I do know I need to show that the negative charge would bounce up and down as if on a spring.
Show that F = -constant * delta y
This is what I have so far that we did in class. He said we needed to make a substitution somewhere but I don’t understand where
2F=[Kq^2/r^2]2
Fy = [2Kq^2/r^2] sin theta
Sin theta = delta y/r
Sin theta = delta y/(d/2)
  • · Replies 20 ·
