Proving lim m(Ei) = m(E) in Measure Spaces
  • Thread starter Thread starter jem05
    Measure
jem05
Let (X , M, m) be a certain measure space and {En} sets in M with the property:
\underline{lim} (Ek) = \overline{lim}(Ek) = E
prove that lim m(Ei) exists and = m(E) as n approaches infinity.
i solved the problem, if it were given that m(\bigcupEi) is stirctly less that infinity, but i don't know how to overcome that problem since that was not given.
any help is appreciated.
thank you.
For the finite version you've proved already, it should be enough to have the hypothesis that m\left(\bigcup_{j\geq n} E_j\right) < \infty for some sufficiently large n, because your problem isn't changed if you throw away finitely many of the E_j from the front. But the negation of this hypothesis is that m\left(\bigcup_{j\geq n} E_j\right) = \infty for every n \in \mathbb{N}, which is a little stronger. Does that help?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
