Proving limit equivalence statements.
  • Thread starter Thread starter cookiesyum
    Equivalence Limit
cookiesyum
Is it always true that
lim f(x) x-->infinity = lim f(1/t)t --> 0
lim f(x)x--> 0 = lim f(1/n)n-->infinity
How can you begin to prove or disprove these statements if you don't know what f is doing to x. In other words, lim f(x) could not exist or it could depending on what f(x) is doing to the x's right? So from where do I start?
not too sure on this one, but as some ideas, consider the 2nd case
lim x->0, f(x)
for the limit to exist, the limit must be same for the approach to zero form both sides
lim x->0+, f(x) = lim x->0-, f(x)
it seems to me changing to the case, lim n-> inf, f(1/n) only really consider the 0+ approach
consider a step function at the origin
however that will only be a problem if the limit does not exist, if the limit does exist then i think you might be ok - however it might be some food for though for the first case what if t approaches 0-, then would you require the negative infinite limit to be the same as the positive one?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
