Proving that a set is not bounded from above.
  • Thread starter Thread starter Skirdge
    Bounded Set
Skirdge
Prove that if a is a real number, a > 1, then the set {a, a^2, a^3, ...} is not bounded from above. Hint: First find a positive integer n such that a > 1 + 1/n and prove that a^n > (1 + 1/n)^n >/= 2.
Showing that there exists a positive integer n such that a > 1 + 1/n is not difficult. Since a > 1, a-1 is a positive real number so there exists an integer 1/n such that a-1 > 1/n and thus a > 1 + 1/n. Proving the second set of inequalities is not difficult either. I'm at a complete loss as to how the hint relates to the problem.
Look at the sequence ##(a^{nk})## as ##k## varies.
Can you prove that {2. 22, 23, 24, ...} is not bounded above?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
