Proving the Limit of x^2sin(1/x) as x Approaches 0 Using Delta-Epsilon Proof
  • Thread starter Thread starter Math_Geek
    Proof
Math_Geek
limit as x goes to 0 of x^2 sin(1/x)=0
Use delta-epsilon proof
So |f(x)-L|=|x^2 sin(1/x)|=|x^2||sin(1/x)| and I know that sin(1/x) is bounded by one. I am not sure how to finish because of the x^2.
… one step at a time … !
Math_Geek said:
So |f(x)-L| = |x^2 sin(1/x)| = |x^2||sin(1/x)| and I know that sin(1/x) is bounded by one. I am not sure how to finish because of the x^2.
Hi Michelle! :smile:
I can't make out whether you've got the answer or not.
You must practise stating things clearly.
And thinking clearly! One step at a time!
First step: what do you think the limit is?
Second step: why do you think it's that (in layman's terms)?
Third step: put second step into delta-epsilon form.
:smile: … three steps to happiness! … :smile:
Have a go!
the limit is 0, I think this because it given, also I know sin(1/x) is bounded by so that leaves x^2, so if I choose my epsilon to be sqrt epsilon. then when you square the x then x^2<epsilon
Right?
… oh happiness … !
Right?
Very good! :smile:
hmm … now we've got you thinking clearly, how about writing clearly?
You see … you meant "… my delta to be sqrt epsilon", didn't you?
… and it would be much better if you got into the habit of actually writing "Given any epsilon > 0, then for any x with |x| < √epsilon, |x^2sin(1/x) |≤ x^2 < epsilon; therefore lim(x¬0) = 0", instead of just thinking it! :rolleyes:
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
