Proving the property of entrophy
  • Thread starter Thread starter A330NEO
    Property
The discussion focuses on understanding the thermodynamic property represented by the derivative -(\frac{dU}{dV})_{S,N}, where U is internal energy, V is volume, S is entropy, and N is the number of particles. Participants emphasize that while entropy and particle number remain constant, changes in volume affect internal energy. The differentiation of the equation provided is suggested to be straightforward, primarily involving the term (\frac{V}{V_0})^{-2/3}. It is noted that the relationship between volume changes and internal energy is crucial for explaining the property in question. Access to relevant thermodynamic equations and concepts is recommended for a comprehensive analysis.
A330NEO
-\left ( \frac{\partial U}{\partial V} \right )_{S, N} is a definition of an imporant thermodynamic property,where S denote the entropy and the subscript 0 denotes reference state, so they must be constant. show what is this property. In your analysis, use the equation below.
\frac{U}{U_{0}} = (\frac{V}{V_{0}})^{-2/3}exp\left \{ \frac{2(S-S_0)}{3k_BN} \right \}
As I thought this was done by first-order ordinary derivative equation, I tried to differentiate it, but I was unable to do so. As this is about entrophy, I think U means current energy and V means volume.
I think this is done by first-order ordinary derivative, but I can't specify.
The way I understand it, this question is not really about entropy. You have to explain what - (\frac{dU}{dV})_{S,N} stands for. So, if it has not already been defined, I guess you have to look at other thermodynamic identities and compare your result to them.
The differentiation should not be that difficult. Since S and N are held constant, you only need to differentiate the (\frac{V}{V_0})^{-2/3} term. Use the power rule.
Entropy does not change, nor do the number of particles; What changes when the internal energy of a system changes due to volume? When you figure that out, you have explained what - (\frac{dU}{dV})_{S,N} stands for.
Then, what kind of property is it?
That seems to be your homework question.
Think about it. You have a closed system (ie its number of particles stay constant). Its entropy does not change either. However, you can change its volume. What happens if you make a canister of gas smaller? If you put your finger into the canister, how would it feel different now compared to before you made the canister smaller? Remember, temperature changes with entropy, and in our case entropy is constant.
Also, I think you should have access to more relevant equations. I am assuming you have a book on thermodynamics. Does it have a section on the internal energy of a system? Or, thermodynamic potentials?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
