Is U a Valid Subspace of R3 When x Equals z?
  • Thread starter Thread starter roam
    Subspace
roam
Let U={(x,y,z) \in R3 : x=z}. Show that U is a subspace of R3.
U is non-empty it contains the 0 vector:
U= {(x,y,z) = (s,t,s), s,t \in R}
U={s(1,0,1)+t(0,1,0), s,t \in R}
for s,t=0
0(1,0,1)+0(0,1,0)=(0,0,0)
closed under addition:
u=(s1,t1,s1)
v=(s2,t2,s2)
u+v=(s1+s2,t1+t2,s1+s2)
Hence x=z
This was my attempt so far, I'm not sure how to prove the 3rd condition... can anyone show me how to prove that it is closed under scalar multipication?
Regards
I assume you are taking scalars in R.
\lambda (x,y,x)=?
You should take an arbitrary element of the set and multiply by an arbitrary scalar and then show the result is still in the set. That's what the definition means!
So,
A vector u=(s1,t1,s1) belongs to the set.
for a scalar \lambda \in R
λ(s1,t1,s1)=λs1,λt1,λs1
Is this all I need to write??
roam said:
So,
Does your vector u belong to set U? If so, you should have that as your conclusion.
Also, from your work in an earlier post, does your vector u + v belong to set U? If it does, you should say that. You concluded "hence x = z" which is not what you should conclude.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
