Pulley on inclined plane problem
The problem involves two blocks connected by a pulley, with one block on a 30-degree incline and the other hanging vertically. The acceleration of the 1 kg block up the incline is calculated to be 4.9 m/s², while the tension in the string connecting the two blocks is determined to be 29 N. The forces acting on the blocks include gravitational force and tension, with the tension overcoming the gravitational pull on the incline. The direction of acceleration for the 2 kg block is also considered, indicating it moves downward. This analysis highlights the dynamics of connected systems on frictionless surfaces.
gdhillon
Q:Two blocks are tied together on an incline The first box is on a 30 degree incline with he horizontal and is 1 KG, the wire from it runs over a pulley that goes to a mass of 2KG . If both the pulley and the incline are frictionless:
a) What is the acceleration of the 1.0 kg block up the incline?
b) What is the tension in the string joining the two blocks.
I first found the FG of the 1KG block and from that used sohcahtoa to get my normal force and my fapp (-9.8sin30) negative because it is 'wanting' to go down the incline away from the 2kg mass. For a) I used Ʃf=ma, 19.6-(9.8sin30)=3a acceleration is 4.9m/s^2
for b) I used Ʃf=ma and had T-19.6=2(4.9) and got tension=29N
gravity wants to pull it down, but the tension wants to pull it up. Tension wins.
yes, what direction?
No. In what direction is the acceleration of the 2 kg block?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
