Pulleys Jh Homework Statement: Understanding the Concept of Pulleys
  • Thread starter Thread starter Jakecp
    Pulleys
The discussion centers on understanding the mechanics of pulleys, specifically regarding the balance of forces and the role of friction. The original explanation highlighted how changing the center of gravity affects the force needed on one side of the pulley, leading to an imbalance. Participants emphasized the importance of considering factors like rope friction and mechanical advantage while clarifying that the pulley remains free to turn. Suggestions were made to refine the explanation by focusing on the differences in distances and the implications for equilibrium. The conversation ultimately aims to help the student articulate their understanding more clearly for their homework assignment.
Jakecp
https://fbcdn-sphotos-b-a.akamaihd.net/hphotos-ak-xfl1/v/t34.0-12/12231095_1486035821701632_2065647312_n.jpg?oh=dd0658f6afcfe91a852c72c3dab01560&oe=564836A2&__gda__=1447576857_f29a19be54068711687d57ac9593225d
None
None[/B]
You need to do more first. Please read the guidelines.
What standard equations or theory do you expect to be relevant?
What have you tried? What's blocking you?
I just need to explain. I explained that the gravity center changed by this and that the pulley had more distance to go through in one side so there was no balance in the pulley making B statement true needing more force baceuse the lack of equilibrium. They put me a 4/10 saying that i made no effort but i have got another chance to improve. I don't know what else to put . Because I'm just in 7th grade i don't think i need an equation but just to explain. Any help is really welcome.
What i wrote :
b) because by changing the axis you are changing the center of gravity of the pulley that causes the need of more force on one side because there is not balance at all. One rope is having more weight than the other causing inequilibrium.
Gravity doesn't enter into it because you are supposed to ignore the mass of the pulley.
It rather implies you should ignore friction too, but that would not be right. You should ignore friction at the axle, but assume enough friction between rope and pulley that the rope does not slip.
Jakecp said:
the pulley had more distance to go through in one side so there was no balance in the pulley making B statement true .
You are on the right lines there. You can you put that more clearly?
Not necessarily an equation, but some relevant theory of mechanics that you may have come across. Think levers
Forget that , i was wrong.
So , it would be b) but not because of the center of gravity but because of the rope friction not allowing the rope to move.
What can i put? I could say that it does not have a mechanical advantage and that you need more force because of the friction.
So , it would be b) but not because of the center of gravity but because of the rope friction not allowing the rope to move.What can i put? I could say that it does not have a mechanical advantage and that you need more force because of the friction.
No, no. The pulley is still free to turn on its axis, it's just that the axis is not in the centre. Don't worry about the friction - I was just pointing out that the rope does not slip on the pulley.
so i was basically right at the beginning ?
The part I quoted in post #4 was getting there, but you weakened your original answer by mentioning several things that are not relevant too. Just concentrate on what it was you meant by the distances being different, and see if you can spell it out more clearly. You mentioned mechanical advantage...
Sometimes it helps to take an extreme example.
Suppose the axis were moved to the point where the left string contacts the pulley.
Then there would be no way to keep the pulley from tipping - right?
Thanks , this was used by my teacher to tell compound bows and how they work
