How Does Aligning Water Dipoles Affect Surface Charge Density?
ResonantW
Imagine that all the molecular dipoles in a cup of water could be made to point down. Calculate the magnitude of the resulting surface charge density at the upper surface of the water, and express it in electrons per square centimeter.
Can I just find the number of water molecules per square centimeter of area, knowing the approximate size of an H2O molecules, and then say that since all the dipoles point down we will have 2 electrons for every such molecule along the surface?
I think you should approach it from the ideas developed in chapter 10. The text gives you the permanent dipole moment, p, of a water molecule. It also explains how to go from dipole moment per molecule to the polarization P. From P you can get the surface charge density. :smile:
Got it! Why wouldn't the first method work?
Also, do I know the volume density of water molecules, because that would be what Purcell calls N, correct?
I don't think you can assume two electrons per molecule. The effective surface charge per surface molecule would depend on the amount of polarization of each molecule, p .
Right. You'll need to determine N, the number water molecules per cm3. See if you can calculate it from the mass density of water and the molar mass of water.
I get that P= 6e22 esu/cm^2. Is that equivalent to the surface charge density?
I can also express this as 1.3e32 electrons per square centimeter.
I think you overlooked the caption for Fig. 10.14 which states that the dipole moments given in the figure are in units of ##10^{-18}## esu-cm. Otherwise, looks good.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
