Crossing Event Horizon of Black Hole: What Happens?
  • Thread starter Thread starter Ironlenny
Ironlenny
You cross the event horizon of a black hole and send that black hole traveling towards a star. When the black hole is in orbit around the star, you (assuming that you can) exit the black hole at the same time as when you entered it. What happens? Is that possible?
From what I understand about black holes, when you have crossed over the event horizon, the dimensions of space collapse to a point, and the only direction that you can move in is time. I asked my self the above questions and I don't know what to make of it.
Hi Ironlenny,
Once something has crossed the event horizon, it can never get out of the black hole. What is happening on the inside is a matter for speculation, since we haven't found any black holes, and even if we did we couldn't interact with the interior.
This is a short answer, but you can use the search menu ( top toolbar) to find other discussions about black holes in this forum.
M
I was under the impression that we have observed phenomenon that behave as we'd expect a black hole to behave. Since they behave like black holes, I believe it's reasonable to assume that they are black holes.
I am curious about your comment on speculation. It seems to imply that a question that can't be answered with our current level of knowledge shouldn't be asked. I want to know how time dilation would effect an object inside the event horizon of a black hole that was accelerated to a fraction of the speed of light. I don't care that it is speculation. I am asking the question for the sake of asking it.
I would also like to point out that you can interact with the interior of a black hole, but you can't send out any information. If you orbit a black hole above the event horizon and send a probe, it will send telemetry right up to the point that it crosses over.
Ironlenny said:
I was under the impression that we have observed phenomena that behave as we'd expect a black hole to behave. Since they behave like black holes, I believe it's reasonable to assume that they are black holes.
Fair enough, but it's not direct evidence.
Why so defensive ? I wasn't criticising your question. I just don't want to take part in speculation.
If you can't receive any data from the region, you're not interacting. Maybe 'interacting' is a bad choice of word.
(my emphasis).
Which supports my point that we can't know directly what's across the horizon.
I realize that you are trying to help, but I am interested in speculation.
I'm sure someone will speculate with you in time. Try searching other threads in the meantime.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
