Pythagorean Theorem and Pendulums
5 replies · 6K views
Soley101
Calculate the maximum speed of the 100 g pendulum mass when it has a length of 100 cm and an amplitude of 50cm. sorry my computer won't access the other thread. i don't know any other laws of conservations of energy or trig very well. also, when the pendulum as an amplitude of 50 cm , how does this lend me knowledge.
pythagorean theorem (i would like to use this).
a=9.8 m/s2
what does amplitude mean, the pendulums height, or how far the pendulum is from its maximum speed point
max of pendulum is at bottom.
pendulum starts gainig speed of a from top till reaches bottom.
I assume that this means the pendulum mass reaches a height of 50cm above the lowest point.
Hint: Consider conservation of mechanical energy.
you cannot solve this problem without using pythagorean theorem, so don't worry :smile:
the amplitude of a pendulum is the displacement of the bob from the equilibrium position. it is not the arc length or anything, it is the displacement.
first draw a figure and call one of the distances you don't know x
then write the others in terms of x
then, u will need to solve a quadratic which u will form by using pythagorean theorem. and u will get 2 values for x. which one do you think is more reasonable to use?
when u get x, construct an equation concerning conservation of energy. think about what the maximum speed impilies
then solve your equation to get the max. speed
the amplitude of a pendulum is defined to be the displacement from the equilibrium position
Good point! :wink:
Soley101 did u get the answer?
