Python Python: How to get my variables out of a function
The discussion centers on creating a Python function to compute g(t) = e^(-a * t^2) and its derivative gderiv(t) = -2*a*t*g(t). The user has successfully defined the functions but struggles with printing the results in the required format, specifically how to include the variables t and a in the output. The solution involves using the input function to allow users to enter values for t and a, which can then be passed to the function. The corrected code includes prompts for user input and ensures the output displays both the function values and their corresponding parameters correctly formatted.
MaxManus
The exercise: Make a Python function for computing
g(t) = e**(-a * t**2) and gderiv(t) = -2*a*t*g(t)
Return the function values of g(t) and gderiv(t). Apply the function to write out a result in the format:
g(1, a=0.5)=0.606531, g’(1, a=0.5)=-0.606531 I have made a function g(t, a) and gderiv(t,a), but I don't know how to print t and a so that i can print the result in the format: "g(1, a=0.5)=0.606531, g’(1, a=0.5)=-0.606531"
from math import e
def g(t, a):
G = e**(-a*t**2)
Gderiv = -2*a*t*G
return G, Gderiv,
G,Gderiv = g(t = 1, a = 0.5)
print "g(%g, a=%g) = %.6f" % (t, a, G)
Edit: The problem is that t and a are not defined.
Technology news on Phys.org
from math import e
def g(t, a):
G = e**(-a*t**2)
Gderiv = -2*a*t*G
return G, Gderiv,
I've never done any programming in python, but I assume that there is an input function which allows the user of your program to input the values of t and a... I'd try something like this:
Code:
from math import e
def g(t, a):
    G = e**(-a*t**2)
    Gderiv = -2*a*t*G
    return G, Gderiv
t=input("Please input value of t   ")
a=input("Please input value of a   ")
G,Gderiv = g(t , a )
print "g'(%g, a=%g) =  %.6f" % (t, a, Gderiv)
And then when you run the program you input the values of t and a when prompted.
Thank you
Dear Peeps I have posted a few questions about programing on this sectio of the PF forum. I want to ask you veterans how you folks learn program in assembly and about computer architecture for the x86 family. In addition to finish learning C, I am also reading the book From bits to Gates to C and Beyond. In the book, it uses the mini LC3 assembly language. I also have books on assembly programming and computer architecture. The few famous ones i have are Computer Organization and...
I had a Microsoft Technical interview this past Friday, the question I was asked was this : How do you find the middle value for a dataset that is too big to fit in RAM? I was not able to figure this out during the interview, but I have been look in this all weekend and I read something online that said it can be done at O(N) using something called the counting sort histogram algorithm ( I did not learn that in my advanced data structures and algorithms class). I have watched some youtube...
