Questions on Convergence of Sequence {an}: Find Its Limits
  • Thread starter Thread starter axe69
    Sequences
The sequence {an} is defined recursively, starting with a1=1 and following the rule an+1=√(1+an/2). To determine convergence, it is suggested to analyze the behavior of the sequence by calculating initial terms, which appear to be increasing. The discussion highlights the importance of applying theorems related to the convergence of increasing sequences. To find the limit, one should take the limit of both sides of the recursive equation, leading to a solvable equation for the limit value. The convergence and limit of the sequence can thus be established through these mathematical principles.
axe69
The sequence {an} is defined by
a1=1,an+1=\sqrt{1+an/2} ,n=1,2,3,4,...
(a) a^2n-2<0 , (b)a^2a+1-a^2n>0. deduce that{an} converges and find its limits?
please help me get the answer...
Mathematics news on Phys.org
Are the (a) and (b) a^{2n-2} and a^{2n-1}- a^{2n}&gt; 0? If so, what is "a" and what do they have to do with the given sequence?
Have you never seen any sequences like this before?? You don't seem to have even tried anything. While looking at a few terms won't prove anything, it might help you see what's happening: a_1= 1, a_2= \sqrt{1+ 1/2}= \sqrt{3/2}, a_3= \sqrt{1+ \sqrt{3/2}/2}= \sqrt{(2+ \sqrt{3/2})/2}. Does that look like it is increasing? Do you know any theorem about convergence of increasing sequences?
As for finding the limit, what happens if you take the limit on both sides of the equation a_{n+1}= \sqrt{1+ a_n/2}?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
