QM: Groundstates and changing Hamiltonians
  • Thread starter Thread starter Niles
    Qm
Niles
At time t<0 I have a Hamiltonian given by:
<br /> H = \left( {\begin{array}{*{20}c}<br /> {\varepsilon _1 } &amp; { - V} \\<br /> { - V} &amp; {\varepsilon _2 } \\<br /> \end{array}} \right)<br />
with the ground state \left| {v_ - } \right\rangle = A\left( {\sqrt 2 - 1} \right)\left| 1 \right\rangle + \left| 2 \right\rangle, where A is some constant.
Now at t=0 the Hamiltonain changes, since \varepsilon_1=\varepsilon_2=0 for t>0.
I have to find the probability of finding the particle in the groundstate of the new Hamiltonian at the time t=0.
Ok, first I have found the groundstate \left| {m_0 } \right\rangle of the new Hamiltonian. Since I have to find the probability of the particle being in the state \left| {m_0 } \right\rangle at t=0, I still need the Hamiltonian for t<0, i.e. I need:
I am a little uncertain of what should be done now. Can you push me in the right direction?
I'm also uncertain, but my guess is that you should first normalize your ground states and then take the square modulus of their inner product to get the probability:
P = |\langle v_- | m_0\rangle|^2
I think we're on the right track, Irid.
I'm quite sure I have to use P = |\langle v_- | \Psi\rangle|^2, but how can I extract \Psi from the Hamiltonian at t=0?
You said that you have Psi, only named it m_0. Anyway, I think one needs to set up an eigenvalue equation and you'll obtain eigenvectors. The one which corresponds to the lowest energy is termed "the ground state".
I have already found (and normalized) the groundstate \left| {m_0 } \right\rangle. But the groundstate is not the same as the wavefunction itself, i.e. the solution of the time-dependant Schrödinger-equation?
Please correct me if I am wrong.
Ok, I worked it out. The particle is in the groundstate, so \Psi(x,0) = \left| {v__- } \right\rangle and the new stationary state is \psi(x) = \left| {m_0 } \right\rangle. That is, we can find the probability as:
<br /> P = |\langle m_0 | v_-\rangle|^2.<br />
Thanks.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
