Understanding Wave Functions and Normalization in Quantum Physics
In summary: I thought the book said that the wave function could only be nonzero between 0 and L, so I did the math for that. When I was told that the wave function could be nonzero anywhere, I got confused and messed up my math.
Techsmart07
I have been taking an introduction to thermal/quantum physics course, and we are passing over quantum right now, and my teacher has us completely bewildered. This course is pre-differential equations, so most of the stuff is broadly explained, and the book has almost no examples for direction.
The figure below shows the wave function [tex]\Psi[/tex](x) for a particle confined between x=0 and x=L.A) Find an expression for A in order that the wave function can be normalized. B) What is the probability of finding the particle in the region 0<x<L/4?
2. relevant formulas
(sorry if its not perfect setup, not used to the math functions on here)
P(x) = [tex]\Psi[/tex]2(x)dx
Honestly, I don't really even know what to do, so I couldn't make an attempt.
I feel lost on this entire section of the book...
Like you said the particle is confined between x=0 and x=L so the chance of finding there is 1.
Because of symmetrie the chance of finding the particle between x=0 and x=L/2 is a half. So 1/2=Int((2*A*x)^2/L^2,x=0...L/2)
Say what? Yes, if I were finding the chance in L/2, that would make sense. However, this provides no explanation (as far as I can see) on how to find A or the chance for L/4.
I don't need a full answer, just somewhere to start. I looked over my formulas twice and couldn't find anything relating to A that uses variables that are offered in this problem, and I don't know the wave function, so I can't just plug it into the probability formula. It feels like either I am missing information, or that I am just overlooking something simple. (For those that have this book, its richard wolfson's University physics volume 2).
You are already given the form of [tex]\psi[/tex]. The only thing missing is the value of A.
If you integrate your formula for the total probability of finding the particle between 0 and L you will get something dependening on A. Now as Bendavid mentioned the total probability of finding the particle somewhere has to be 1. So you can determine the value of A.
You have a graph of it, showing the parameters A and L, which you can assume as given. The graph consists of two straight line segments. What's the equation of a straight line?
A straight line that goes as you showed us. The reason I only go from zero to a half L is that otherwise you have to split up you intergral. The only reason to work out that intergral is to get the value of A.
The normalization condition for a wave function ψ(x) is
[tex]\int_{-\infty}^{\infty} |\psi(x)|^2\,dx = 1[/tex]
In this problem, ψ(x) is non-zero only between 0 and L, so you have
[tex]\int_{0}^{L} |\psi(x)|^2\,dx = 1[/tex]
Find the function that describes ψ(x), evaluate the integral, and solve for A.
Ok, I understand now. Sorry, i misinterpreted what was said.
1. What is quantum mechanics?
Quantum mechanics is a branch of physics that studies the behavior and interactions of particles at the atomic and subatomic level. It explains how particles such as electrons and photons behave and interact with each other.
2. How is quantum mechanics different from classical mechanics?
Quantum mechanics is different from classical mechanics in several ways. In classical mechanics, the behavior of particles is determined by their position, velocity, and forces acting upon them. In quantum mechanics, the behavior of particles is described by a wave function, which gives the probability of a particle's location or behavior. Additionally, quantum mechanics allows for the concept of superposition, where particles can exist in multiple states simultaneously.
3. What is the uncertainty principle in quantum mechanics?
The uncertainty principle is a fundamental principle in quantum mechanics that states that it is impossible to know both the position and momentum of a particle with complete precision. This is due to the wave-like nature of particles at the quantum level, and the act of measuring one property affects the other.
4. How is quantum mechanics being applied in modern technology?
Quantum mechanics has been applied in various modern technologies, such as transistors, lasers, and magnetic resonance imaging (MRI) machines. It is also being researched for potential applications in quantum computing, cryptography, and teleportation.
5. What are some common misconceptions about quantum mechanics?
There are many common misconceptions about quantum mechanics, such as the idea that it only applies to very small particles or that it can be used to explain consciousness. Another misconception is that quantum mechanics allows for the possibility of parallel universes or time travel. These ideas are not supported by current scientific understanding of quantum mechanics.
