Quantum mechanical derivation of Einstein's equations
Barnytron
This result will shortly revolutionize physics. This short paper breaks the barrier which has kept time as a C-number in the quantum theory while the other spacetime dimensions are operators. Amazing!
http://vixra.org/abs/1209.0010
ABSTRACT: A non-unitary quantum theory describing the evolution of quantum state tensors is presented. Einstein’s equations and the fine structure constant are derived. The problem of precession in classical mechanics gives an example.
Did someone actually spend the time to write a paper like that just to troll physics?
Welcome to PF;
Has that paper been submitted for peer-review anywhere?
<reading> hmmm ... looks like the sort of thin you get from a random paper-generator.
Author's affiliation "Occupy Atlanta" at the start and the Anonymous logo at the end are suggestive...
Author has also:
http://vixra.org/author/jonathan_tooker
Only "sort of like" is what I said ... It has a similar peppering of jargon for eg. I like the way the golden ratio gets plugged into equations, apparently, without motivation. (All right - there's a reference to another vixra paper by the same author.)
vixra is a long way off the "low tier open access journal" indicated in the slashdot article. But you are right - it would have involved more effort than just running some kind of random-article generator... program... thingy.
Normally, vixra papers are not suitable for PF. (Did you read the PF guidelines?)
My 1st clue that something is amiss is the title: "Tempus Edax Rerum". :rolleyes:
My 2nd clue is the bottom half of the 1st column of the 1st page. The author (Tooker) defines
$$N ~=~ \{ x_-^\mu \in S | t_{min} \le t < t_0 \}$$$$H ~=~ \{ x^\mu \in S | t = t_0 \}$$$$\Omega ~=~ \{ x_+^\mu \in S | t_0 < t \le t_{max} \}$$(without defining ##S## any better than as a "Minkowski picture" -- without clarifying what he means by that). He also doesn't define ##t_{min}, t_{max}##. He also seems think that $$\{N, H, \Omega\}$$ constitute a Gel'fand triple -- showing that he has no idea what a Gel'fand triple is. His ##N## is not dense in ##H## in any sense. Hey, ##H## is not even a Hilbert space.
Then he says:
Tooker said:
The past and future light cones define the spaces ##N## and ##\Omega##.
Huh? He just defined ##N## and ##\Omega## as something else. Then he says
Tooker said:
...and the hypersurface of the present is a 3D delta function ##\delta(t-t_0)## in a 12D bulk. The present is defined according to the observer so it is an axiom of this interpretation that the observer is isomorphic to the delta function.
This is bizarre enough, but then he immediately contradicts himself:
Tooker said:
With foresight, we point out that the Dirac delta does not have the properties which will be required of the observer function. We will require that this function returns an undefined value where the argument is null. [...]
Clearly, he doesn't understand that the Dirac delta is not a function but a distribution. So I guess it's not surprising he's also clueless about a Gel'fand triples.
Barneytron said:
Amazing!
It's not amazing -- it's crackpot rubbish.
@Moderators: I submit that this thread be locked for contravening the PF rules.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
If we release an electron around a positively charged sphere, the initial state of electron is a linear combination of Hydrogen-like states. According to quantum mechanics, evolution of time would not change this initial state because the potential is time independent. However, classically we expect the electron to collide with the sphere. So, it seems that the quantum and classics predict different behaviours!
According to recent podcast between Jacob Barandes and Sean Carroll, Barandes claims that putting a sensitive qubit near one of the slits of a double slit interference experiment is sufficient to break the interference pattern. Here are his words from the official transcript: Is that true? Caveats I see: The qubit is a quantum object, so if the particle was in a superposition of up and down, the qubit can be in a superposition too. Measuring the qubit in an orthogonal direction might...
