How Many Quantum Bound States Exist Semi-Classically?
jc09
How many bound states are there quantum mechanically ?
We are told to approach the problem semi classically.
Consider the Hamiltonian function
H : R 2n → R
(whose values are energies), and for E0 < E1 the set
{(p, x) ∈ R 2n |H(p, x) ∈ [E0 , E1 ]} ⊆ R 2n
which we assume to have the 2n-dimensional volume V (2n) . It is a fact that when-
ever V (2n) is finite, then there are only finitely many (distinguishable) quantum
mechanical states. More precisely, one has
V (2n) hn ≈ ♯{states of energy E ∈ [E0 , E1 ]},
where h = 2π. Moreover, strict equality holds provided the l.h.s. is an integer.
Asked to consider
asked to consider the Hamiltonian function
H(p, x) = p1^2 2m1 + p2^2 2m2 + 1 /2 m1 ω 1^2 x1^2 + 1/ 2 m2 ω 2^ 2 x2^2 ,
and to determine the approximate number of states of energy E
≤ Etotal .
Hint: This is the equation of an el lipsoid in 4-dimensional phase space with
coordinates (p1 , p2 , x1 , x2 ). The volume of the ellipsoid with radii a, b, c, d is abcd
times the volume of the 4-dimensional unit sphere
I'm stuck trying to find a starting point for the problem
If I recall this method correctly, $ N \approx \int d^np d^n x/(2\pi\hbar)^n$, where N is the number of states - it is just the amount of "cells" in phase space. The integral should be taken over the whole possible space in it. In your case this space is 4-dimensional (p1, x1, p2, x2) and is bounded by the energy conservation law:
$ E = p_1^2/2m_1 + m_1 \omega_1^2 x_1^2 /2 + p_2^2/2m_2 + m_2 \omega_2^2 x_2^2 /2 \le E_{total}$
This is an equation of a 4 dimensional ellipsoid.
To calculate the n-dimensional surface of a unit sphere do the following:
consider the integral $\int \exp(-r^2)d^n r$ over the whole space. Now write $ d^n r = \Omega_n r^{n-1} dr$ where $\Omega_n$ is the surface of a unit n-dimensional sphere. Substituting $ r = \sqrt{z}$ you get gamma function
$\int \exp(-r^2)d^n r = \Omega_n \Gamma(n/2)/2$.
On the other hand, the integral can be represented as
$\int \exp(-r^2)d^n r = \int_{-\infty}^{+\infty}\exp(-x_1^2)dx_1 \times \int_{-\infty}^{+\infty}\exp(-x_2^2)dx_2 \times ... \times \int_{-\infty}^{+\infty}\exp(-x_n^2)dx_n$.
Each of these integrals is Poisson integral and is equal to $\sqrt{\pi}$. Comparing both sides you get at last
$\Omega_n = 2 \pi^{n/2}/\Gamma(n/2)$.
For instance, when n = 2 ("surface area" of a circle) this gives $\Omega_2 = 2 \pi/\Gamma(1)=2\pi$,
for n = 3 taking into account that $\Gamma(3/2) = 1/2 \times \Gamma(1/2) = \sqrt{\pi}/2$ you get (as it should be) $\Omega_3 = 4\pi$
in your case n = 4 and so $\Omega_4 = 2\pi^2$.
Good luck!
Good luck!
So This means that I have my surface area which is 2*pi(squared) and what I should do is integrate over this within the region of the 4 dimensional ellipsoid?
Well, if I recall this method correctly :wink: all you have to do is just find the volume of the 4-dimensional ellipsoid given it's radii a,b,c,d (you can extract them from the energy conservation law). As it is said in your first post this volume is equal to a*b*c*d*2*pi^2. Then divide this volume by $ (2\pi\hbar)^4$.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
