Quantum mechanics - infinite square well problem
12 replies · 3K views
Graham87
For a wave function evaluate the following integral
Infinite square well equations
I have solved c), but don’t know how to solve the integral in d.
It looks like an integral to get c_n (photo below), but I still can’t figure out what to make of c) in the integral of d).
I also thought maybe you can rewrite c) into an initial wave function (photo below) with A,x,a but don’t know how.
Thanks!
Consider using a trig identity to write ##\sin\left(\frac{2\pi}{a}x\right)\cos\left(\frac{2\pi}{a}x\right)## in a way that will be helpful in evaluating the integral.
I tried like this already, but I still don’t know how to deal with c) in the integral.
OK, good. Can you relate ##\large\frac{\sin\left(\frac{4\pi x}{a}\right)}{2}## to one of the ##\psi_n(x)##?
ψ4(x) ?
Graham87 said:
ψ4(x) ?
Exactly what is the relation between ##\large\frac{\sin\left(\frac{4\pi x}{a}\right)}{2}## and ##\psi_4(x)##?
Same n?
How does this look?
I don’t think it’s correct because c_4 is not the same answer.
Graham87 said:
How does this look?View attachment 303556
That will work.
However, it's maybe a little nicer to show ##\large\frac{\sin\left(\frac{4\pi x}{a}\right)}{2} = \frac{\sqrt{2a}}{4}\psi_4(x)## . Then you don't need to do any explicit integration. Just use the orthonormality of the ##\psi_n(x)##.
TSny said:
That will work.
So like this?
I found the integral d) similar to this.
Is it wrong to assume that c_4 should be the same as my answer in d)?
In that case my answer in d is not correct.
You're asking, are
$$\frac{\sqrt{2a}}{4} \int \psi_4^2\,dx$$ and $$\int \psi_4^2\,dx$$ equal? I think you should be able to answer that on your own. :)
You need to calculate ##\int_0^a{\sin\left(\frac{2\pi x}{a}\right)\cos\left(\frac{2\pi x}{a}\right)}\Psi(x,0)dx##
Write this as ##\frac{\sqrt{2a}}{4}\int_0^a\psi_4(x)\Psi(x,0)dx##.
Substitute the given expression for ##\Psi(x,0)## and evaluate using the orthonormality of the ##\psi_n(x)##.
You should get the same answer as you got in post #7.
  • Love
Big thanks! Got it!
Graham87 said:
Big thanks! Got it!
In general, it's a good habit to use the notation ##\psi_n(x)## and use the general properties of eigenfunctions - especially orthonormality - as much as possible. And only resort to the specific eigenfunctions when necessary.
