Quantum Oscillator States: Is the Ladder Operator Enough?
The discussion revolves around the completeness of the energy states derived from the ladder operator in the context of a quantum harmonic oscillator. Participants explore the implications of the ladder operator's application, the quantization of energy levels, and the assumptions underlying these derivations.
  • Some participants express skepticism about the completeness of the solutions obtained using the ladder operator, questioning whether additional states could exist between the quantized energy levels.
  • Others argue that the ladder operator can indeed demonstrate the quantization of energy levels, asserting that applying the lowering operator leads to a contradiction if energy states were not quantized.
  • A few participants emphasize the necessity of assuming irreducibility in the representation of operator algebra to arrive at a complete set of orthogonal eigenstates.
  • Some contributions highlight the uniqueness of the ground state and its implications for the derivation of other energy eigenstates through the ladder operator.
  • There are discussions about the potential degeneracy of states when considering additional factors like spin in the harmonic oscillator model.
Participants generally do not reach a consensus, with multiple competing views on the completeness of the energy states and the assumptions required for the ladder operator's application. The discussion remains unresolved regarding the implications of these differing perspectives.
Some participants note that the discussion relies on specific assumptions about the Hamiltonian and the nature of the eigenstates, which may not be universally applicable. The potential for degeneracy in states is also raised as a limitation in the context of certain systems.
This discussion may be of interest to students and researchers in quantum mechanics, particularly those exploring the foundations of quantum harmonic oscillators and the mathematical formalism involved in their analysis.
Mayan Fung
We learned that we can use the ladder operator to obtain the states of a quantum oscillator. However, I see no direct evidence to show that the solutions are complete. I mean, how can we know the energy state follows E is (E+hw). Why can't we have some more states in between? Does the derivation using ladder operator prove this?
Have a look at the Wiki article, which answers your questions.
https://en.wikipedia.org/wiki/Quantum_harmonic_oscillator
As is said in the Wikipedia article Mentz114 mentioned, suppose you have a state [itex]|\psi\rangle[/itex] with positive energy eigenvalue [itex]E[/itex]. If you apply the lowering operator [itex]a[/itex], you'll get another eigenstate with energy [itex]E-\hbar \omega[/itex]. If you keep applying [itex]a[/itex], you will come up with a state [itex]|\psi'\rangle \equiv a^n |\psi\rangle[/itex] such that [itex]H |\psi'\rangle = (E - n \hbar \omega) |\psi'\rangle[/itex]. Pick [itex]n[/itex] large enough so that [itex]E - n \hbar \omega < 0[/itex]. It's impossible for the energy to be negative (for this particular hamiltonian, anyway). So that's a contradiction, unless [itex]|\psi'\rangle = 0[/itex]. So we conclude that:
If [itex]|\psi\rangle[/itex] is any energy eigenstate, then there is some number [itex]n[/itex] such that [itex]a^n |\psi\rangle = 0[/itex]
Additionally you have to assume that the representation of the usual operator algebra should be irreducible. Then the harmonic oscillator Hamiltonian is non-degenerate (for this one-dimensional case), and you get a complete set of orthogonal eigenstates, because the Hamiltonian is self-adjoint.
Well, it follows from the Schrödinger equation for the harmonic oscillator. If you solve (e.g. by power series method) it and apply the boundary conditions and normalization, you find that the energy is quantized, ##E_n=\left(n+\frac{1}{2}\right)\hbar \omega##.
maxverywell said:
Well, it follows from the Schrödinger equation for the harmonic oscillator. If you solve it and apply the initial conditions and normalization, you find that the energy is quantized, ##E_n=\left(n+\frac{1}{2}\right)\hbar \omega##.
I interpreted the question as asking how to demonstrate this using the ladder operators.
I think that in order to use the formalism of the ladder operators you have to presuppose that the oscillator is quantized.
No, you use the ladder operators to derive that the energy of the ho is quantized. Since ##\hat{H}## is positive semidefinite and ##\hat{a}##, applied to any energy eigenstate leads to an energy eigenstate with an energy by ##\hbar \omega## lower or 0. Thus there must be an energy eigenstate ##|\Omega \rangle## which is mapped to 0 by ##\hat{a}##. Then using ##\hat{a}^{\dagger}## you can get all energy eigenstates by applying it multiple times to ##|\Omega \rangle##. Assuming then that the Heisenberg algebra is realized irreducibly this leads to a complete orthnormal basis of energy eigenvectors.
No, I would say that the ladder operators prove this, rather than presuppose it.
  1. All eigenvalues of [itex]H[/itex] are positive.
  2. For any eigenstate [itex]|\psi\rangle[/itex] of [itex]H[/itex], if [itex]H|\psi\rangle = E |\psi\rangle[/itex], then for any positive integer [itex]n[/itex], [itex]H (a^n |\psi\rangle) = (E - n \hbar \omega) (a^n |\psi\rangle)[/itex].
  3. If [itex]E - n \hbar \omega < 0[/itex], this is only possible if [itex]a^n |\psi\rangle = 0[/itex]
  4. So let [itex]n[/itex] be the smallest non-negative integer such that [itex]a^{n+1} |\psi\rangle = 0[/itex].
  5. Then the state [itex]|\psi_0\rangle \propto a^n |\psi\rangle[/itex] is nonzero, and satisfies [itex]a |\psi_0\rangle = 0[/itex]. (I'm using [itex]\propto[/itex] to mean equal, up to a multiplicative normalization constant).
  6. There is only one normalizable state satisfying that equation.
  7. If [itex]a^n |\psi\rangle \propto |\psi_0\rangle[/itex], then we can show that [itex](a^\dagger)^n |\psi_0\rangle \propto |\psi\rangle[/itex]
  8. So since [itex]|\psi_0\rangle[/itex] is unique, that shows that every eigenstate [itex]|\psi\rangle[/itex] can be written in the form [itex]|\psi\rangle \propto (a^\dagger)^n |\psi_0\rangle[/itex] for some nonnegative integer [itex]n[/itex].
  9. So the eigenstates are quantized.
I think you presuppose that ##E=m\hbar\omega+c##, where ##m## is integer and ##c<\hbar\omega##.
In this case there is indeed a unique ##\psi_0## with energy ##E_0=c##, and any other eigenstate ##\psi## is created by applying ##\hat{a}^n## on ##\psi_0##.
But if [itex]E[/itex] is a real number, then it's got to be the case that [itex]E[/itex] can be written as [itex]E = n \hbar \omega + c[/itex] for some [itex]c \leq \hbar[/itex].
Not if ##c## is the same for all ##E##, as you have supposed in your proof.
In other words, why in your proof ##\psi_0## is unique (same for any ##\psi##)?
Because there is only one solution to the equation [itex]a |\psi_0\rangle = 0[/itex] (up to a multiplicative constant).
If you look at what [itex]a[/itex] is, it's
[itex]a = \sqrt{\frac{m \omega}{2 \hbar}} (x + \frac{i}{m \omega} p) = \sqrt{\frac{m \omega}{2 \hbar}} (x + \frac{\hbar}{m \omega} \frac{\partial}{\partial x})[/itex]
So [itex]a |\psi_0\rangle = 0[/itex] means [itex]x \psi_0(x) + \frac{\hbar}{m \omega} \frac{\partial}{\partial x} \psi_0(x) = 0[/itex]
So [itex]\frac{\partial \psi_0}{\partial x} \frac{1}{\psi_0} = -\frac{m \omega x}{\hbar}[/itex]
The left-hand side is just [itex]\frac{\partial log(\psi_0)}{\partial x}[/itex]. So we have:
[itex]\frac{\partial log(\psi_0)}{\partial x} = - \frac{m \omega x}{\hbar}[/itex]
Integrate both sides with respect to [itex]x[/itex] to get:
[itex]log(\psi_0) = - \frac{m \omega x^2}{2 \hbar} + C[/itex]
where [itex]C[/itex] is some constant. So:
[itex]\psi_0 = e^{- \frac{m \omega x^2}{2 \hbar} + C} = C' e^{- \frac{m \omega x^2}{2 \hbar}}[/itex]
where [itex]C' = e^{C}[/itex]. So [itex]\psi_0[/itex] is uniquely determined (up to the multiplicative constant [itex]C'[/itex])
I don't know of a way to prove that [itex]a |\psi_0\rangle = 0[/itex] has a unique solution without actually looking at what [itex]a[/itex] is.
Well, this however assumes that the ground state of the HO is non-degenerate. Take a particle with spin with the HO potential only (i.e., no magnetic fields around). Then the ground state (and thus all other energy eigenstates) are ##(2s+1)##-fold degenerate.
All of your views give me new insight into this! Thanks! But I am still digesting your words...
  • · Replies 16 ·
