B Quantum vs. Classical Mechanics in Differential Element Analysis
Differential elements in classical mechanics, such as those used in the heat diffusion equation, typically do not account for quantum effects because the phenomena being analyzed are at a macroscopic level. Energy conservation is applied to these elements by considering incoming and outgoing energy, energy generation, and changes in stored energy. Quantum effects become negligible in these scenarios, as they do not significantly alter the outcomes of macroscopic calculations. An example discussed includes the energy levels of a satellite, where quantum calculations yield results that align closely with classical mechanics at larger scales. Thus, for most practical applications, classical mechanics suffices without the need for quantum considerations.
Meet Gandhi
When we take a differential element for analysis why don't we consider quantum effects and only consider classical mechanics to solve the problem?
Can you elaborate, perhaps with an example, of what you are asking about with differential elements. I would rather not speculate.
When we derive the heat diffusion equation which is a differential equation, we consider a differential element and the apply energy conservation.
In this conservation equation, we take energy coming in and going out, energy generated and change in energy stored.
Here the element is assumed to be infinitesimally small then why don't we consider quantum effects and include quantum energy terms?
Hope this suffice.
Maybe not the exact answer you are looking for, but maybe this will help.
Since the effect that you are interested in is at the macroscopic level, I don’t think that making quantum level calculations will provide any advantage.
I don’t recall about heat transfer, when I took the advanced Physics class, which involved quantum calculations. But we did do some calculations which had to do with motion. One in particular, that I can recall, had to do with a satellite orbiting Earth hundreds of km above the surface.
We had to calculate the next energy level up or down for the satellite, using quantum calculations. It turned out the difference in energy levels was on the order of nanometers, I think. It was small enough, that we could say that standard Newtonian mechanics and quantum mechanics produce the same result, when looking at macroscopic events.
Likes Dr.D
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
