How Do Voltage Changes Affect Fields in a Quasi-Electrostatic Capacitor?
  • Thread starter Thread starter NotHeisenburg
    Capacitor
NotHeisenburg
I am trying to find the electric and magnetic fields between two parallel circular plates, where one plate is grounded and the the other has a voltage that increases linearly with time. I need the E field between plates, and I can ignore fringing fields. The permativity is specified to be ##\epsilon_0##.
## V(t)=at ## where ##a## is a constant.
The radius of the plates is given to be ##R##
##E(\vec{r},t)=\frac{1}{4\pi\epsilon_0}\int\frac{(\vec{r}-\vec{r}')\rho(\vec{r}',t)d^3r'}{|\vec{r}-\vec{r}'|^3}##
##\rho(\vec{r},t)=##?
With the E field I would find the B field using
## \nabla \times B=\mu_0\vec{J}+\frac{1}{c^2}\frac{\partial E}{\partial t} ##
It sounds like a simple parallel plate capacitor setup. You can find the plate area easily enough from the given radius. Do you have a value for plate separation?
I would assume that I could just call the plate separation ##d##
Sure. And it's well known that, ignoring edge effects, the electric field between the plates of a parallel capacitor is uniform.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
