How can a particle be its own antiparticle?
  • B
  • Thread starter RJ Emery
  • Tags
    Particle
In summary: It's just a term we use to describe a certain type of reaction. In summary, the process of particles meeting their antiparticles and producing other particles is known as particle annihilation, but it can also be referred to as reaction or decay depending on the specific circumstances. It is ultimately just a label and does not have any physical significance.
RJ Emery
113
TL;DR Summary
matter, anti-matter pair
I seek an explanation as to how a particle can be its own anti-particle. I would think the instant such a particle comes into existence, it would self-annihilate.
RJ Emery said:
Summary:: matter, anti-matter pair
Why? There is absolutely no rationale for such an argument.
If a particle meets its antiparticle it is possible that the two react. If the reaction products are massless or much lighter (which is again possible but not guaranteed) we typically call this reaction "annihilation". The classical example is electron+positron -> 2 photons.
Such a reaction always needs two particles. If you have a single particle then it might be able to decay. As an example, a Z boson (which is its own antiparticle) will decay quite quickly, typically to a particle+antiparticle pair. A W boson will decay very fast as well, but it cannot be a particle+antiparticle pair as the W boson has an electric charge. A photon (which is its own antiparticle as well) can't decay, it is stable.
Likes etotheipi and jim mcnamara
Can two photons annihilate? I would think not because they don't interact very strongly. But they can interact. Delbruck scattering is an example. I'm confused.
There is the maxim that "if a process does not violate a conservation law, it should happen".
How to pinpoint the conservation law violated by decay of a photon into several?
You can take care of energy conservation (resulting photons combined have the same energy as the initial), momentum conservation (products combined have the same momentum, meaning they travel in the same direction), angular momentum conservation (suitable state of polarization).
Classically it´ s obvious - a plane wave of a given frequency cannot spontaneously change its frequency. But viewing it as a photon subject to conservation laws only, which one specifically forbids it to do such an absurd thing?
Yes. Since an electron-positron pair can annihilate to two photons, two photons (given sufficient invariant mass for the pair) can reverse this process. What the cross section is is another matter.
Likes vanhees71
They can react (and we have found reactions), but I don't think "annihilation" is a good name for that.
There is some symmetry that tells you the cross section is exactly zero, I forgot the name.
There is also an interesting consistency argument that you can find in more detail with the search function: If a photon can decay, how does its lifetime depend on the energy? It turns out it's impossible to make that decay Lorentz invariant without absurd consequences.
In QED a positron and electron can annihilate to form 2 photons. Just run the reaction diagrams backward in time and I'm good to go. So yeah, looks like annihilation of photons to me.
##H\to\gamma\gamma## is a decay but ##\gamma\gamma\to H## is not. ##e+p \to n+\nu## is electron capture but ##n+\nu \to e+p## is neutrino capture. There is no rule that would give time-reversed processes the same name.
Then what are the rules? Particle meets antiparticle to produce other particles is the definition of particle annihilation hocked up by Google when queried. Is there a more technically correct one?
What I wrote earlier:
But ultimately it doesn't matter. You can call annihilation what you want as long as it doesn't lead to confusion.
Related to How can a particle be its own antiparticle?
1. How can a particle be its own antiparticle?
This phenomenon is known as particle-antiparticle duality, where a particle and its antiparticle have the same mass but opposite charge. This is possible because in quantum mechanics, particles are described as wave-like entities, and their properties, such as charge, can be positive or negative.
2. What evidence do we have for particles being their own antiparticles?
One of the most well-known examples is the electron and positron. When these two particles collide, they can annihilate each other and produce high-energy photons. This process has been observed in particle accelerators, providing strong evidence for particle-antiparticle duality.
3. Can any particle be its own antiparticle?
No, not all particles have antiparticles. Only particles that are their own antiparticles are called "Majorana particles." These include the neutrino and hypothetical particles such as the Majorana fermion.
4. How does the concept of particle-antiparticle duality relate to the Big Bang theory?
The Big Bang theory suggests that the universe was initially filled with equal amounts of matter and antimatter. As the universe expanded and cooled, particles and antiparticles began to annihilate each other, leaving behind a small amount of matter that makes up our present-day universe.
5. What implications does particle-antiparticle duality have for energy and mass conservation?
Particle-antiparticle duality does not violate the law of conservation of energy and mass. When a particle and antiparticle annihilate each other, they produce energy in the form of photons. This energy is equivalent to the mass of the particles, according to Einstein's famous equation E=mc^2.
12K
