thomas49th
- 655
I can't think of a way to "show that y=...". Do I compare to x values?
Thx
I don't even know what that means!thomas49th said:(x,y) - (x,0) = (x,y) -(0,2)
is that right?
Nooo!thomas49th said:LHS
x - x = 0
y - 0 = y
RHS
x - 0 = x
y - 2 = y - 2
SO
y = x + y - 2
x = 2
that right?
I thought most people would have seen that formula at least a couple of years before they turn 16!thomas49th said:ive never ever seen that formula in my life, and I think it is beyond GCSE level (that exams you do in UK when your 15 or 16). Is that formula the simplest way?
It is. You're right.cristo said:Is it not just Pythagoras' Theorem in a different guise?
Rhythmer said:Well, I've already experienced some moderators deleting my posts in this section on which I answer homework questions, but I think I'm allowed to answer this one simply because it's not homework.
Well, cristo would follow Halls' hint, using Hootenanny's formula for the distance, and then set them equal.how would cristo go about solving it then?
thomas49th said:What did I do wrong when I add/subtracted the co-ordinates? I know you can only add/subtract the x from x and y from y. I had a look here http://www.bbc.co.uk/schools/gcsebitesize/maths/shapeih/transformationshrev2.shtml
Can someone point me in the right direction.
Is (x,y) - (x,0) = (x,y) -(0,2) right?
The webpage above is for vector displacement not distance between points.
thomas49th said:So how do I find the distance between points?
thomas49th, if you are serious about this, then this suggests that you are either misplaced in your course, or you are studying on your own and beyond your level of achievement. What course are you enrolled in? IF you are enrolled in "Algebra 2" or Intermediate Algebra, then you have been taught the distance formula. In case you are just now in the course being introduced to the distance formula, then study your book very carefully. Again, as reminder, you probably will find an example in your book much like the question which you have here been asking.thomas49th said:So how do I find the distance between points?
symbolipoint said:thomas49th, if you are serious about this, then this suggests that you are either misplaced in your course, or you are studying on your own and beyond your level of achievement. What course are you enrolled in? IF you are enrolled in "Algebra 2" or Intermediate Algebra, then you have been taught the distance formula. In case you are just now in the course being introduced to the distance formula, then study your book very carefully. Again, as reminder, you probably will find an example in your book much like the question which you have here been asking.
"Question 21 - Final question on higher paper" is a commonly used term in the education system, referring to the last question on a higher level exam paper. This question is usually more challenging and requires a deeper understanding of the subject matter.
Not necessarily. While "Question 21 - Final question on higher paper" may be more challenging than previous questions, it does not always mean it is the most difficult on the entire exam. Difficulty can vary depending on the subject and the individual taking the exam.
It is important to read and understand the question carefully before attempting to answer it. Break down the question into smaller parts if necessary and use any available resources, such as formulas or diagrams, to help you. It is also important to manage your time effectively and not spend too much time on one question.
It is not recommended to skip "Question 21 - Final question on higher paper" unless absolutely necessary. This question is often worth a significant amount of marks and can impact your overall grade. If you are running out of time, try to at least attempt the question and provide some reasoning or equations to show your understanding.
The best way to prepare for "Question 21 - Final question on higher paper" is to consistently practice and review material throughout the year. Make sure you have a strong understanding of the subject matter and familiarize yourself with different question formats. It is also helpful to practice time management and test-taking strategies to ensure you have enough time to complete the final question.
