Question about 12v Solar charger?
The discussion revolves around the use of a 12V DC solar panel for trickle charging a jetski battery. Participants explore the relationship between voltage, current, and power output, particularly in the context of using a buck converter to adjust voltage levels and potentially improve charging efficiency.
  • One participant questions whether reducing the voltage with a buck converter would increase current and thus charge the battery more effectively.
  • Another participant explains that the conversion efficiency of solar panels limits the maximum power output, suggesting that power (P) remains constant and cannot be amplified.
  • A participant expresses confusion about the relationship between voltage and current, asking if halving the voltage would indeed double the current and whether this would improve charging.
  • Some participants mention that the open circuit voltage of the solar panel may not reflect its actual operating voltage when connected to a battery.
  • Concerns are raised about the conservation of energy, with one participant stating that energy input into the battery remains constant regardless of voltage and current variations.
  • Discussion includes the potential use of Maximum Power Point Tracking (MPPT) devices to optimize energy transfer under varying conditions.
  • Another participant suggests that for small installations, using more solar panel area may be a more cost-effective solution than MPPT devices.
  • There is mention of different types of charge controllers and their roles in managing charging rates to prevent battery damage.
Participants express differing views on the effectiveness of reducing voltage to increase current for better charging. There is no consensus on whether this approach will yield better results, and the discussion remains unresolved regarding the optimal charging method.
Participants acknowledge various assumptions, such as the efficiency of the solar panel and the characteristics of the buck converter. The discussion also highlights the variability of solar power output based on environmental conditions.
This discussion may be useful for individuals interested in solar energy applications, battery charging techniques, and those exploring the technical aspects of solar panel performance and efficiency.
beany_bot
Hi, I recently bought a smallish 12v DC solar panel for trickle charging my jetski battery. I've had a look at the panel with a multimeter and in good sunlight it makes easy 24V but very very low current. I was wondering if I stick a 99pence buck converter on in, forcing the voltage to a max of 14V. will this increase the current and in turn charge the battery quicker/better?
Don't know too much about these things so came here to ask the experts. Just I had a thought pop into my head that if I reduce the voltage I would get more current and charge the battery more? Is this the case?
I'm not an expert but I would try to do an aswer.
First, the convertion from radiant energy to electrical one is function of the efficience factor which is not equal to one, and this limits the maximum of obtained power by the solar device.
Second, if this device has a power P, say for example 2.4 watt, that is P = VI = 24 x 0.1, then the current converter get in input this power and it can't amplify it, because it must keep constant.
So since P = VI and V= 12 for example in the second device, the current must be about 0.2 A, that is the current is double.
But this in the case that the efficience of the current converter is 1.
Thank you for your reply and forgive my ignorance. So I'm right in thinking, by halving the voltage I'm doubling the current? Now, would this be better at charging the battery? Or because "P" is still "P" will it not make a difference? Thanks.
Hi beany_bot. http://img96.imageshack.us/img96/5725/red5e5etimes5e5e45e5e25.gif
In principle, the idea sounds feasible. Does the panel's documentation indicate its rated current output?
It doesn't state the current output, it "claims" 1.5W but as we know it will be very variable depending on sunlight. This is it http://www.amazon.com/dp/B000R0UBT8/?tag=pfamazon01-20
The amps are very very low, just a trickle charge. Basically wondering if increasing the amperage with lower voltage will charge faster or because the power is the same it won't make a difference.
Look at some data sheets, see whether you can find an efficient buck converter that demands low current for itself. You may be able to boost the current capability so the battery charges a bit faster.
I was just looking at this guy http://www.ebay.co.uk/itm/1PCS-Output-1-25V-35V-DC-DC-Buck-Converter-Step-Down-Module-LM2596-Power-Supply-/271528251706?pt=LH_DefaultDomain_3&hash=item3f3858513a
How did you measure the current? Shouldn't the voltage and current come into equilibrium depending on the load?
I haven't measured the current. I just assumed it is very low because...well, its a small solar panel operating in Scotland on a cloudy day lol.
A won't lie, a lot of this is going over my head, (I don't really have much knowledge about electrical physics).
Was just essential wondering if more amps / less volts will charge the battery better. And indeed will a buck converter do just that? will decreasing the voltage increase the amps? I was led to believe it will. Alas, doesn't more amps less volts just mean its getting more current, but slower, making the overall "energy" delivered to the battery in any given time frame the same? Argh my head hurts...
Well, I'm a mechanical engineer, not an electrical engineer, so I'll want someone else to verify, but typically the open circuit voltage isn't the real operating voltage on an unregulated source like a solar cell or battery. It naturally finds its own equilibrium with the circuit. If it is rated for 12V but produces 24V open circuit and you hook it up to a 12V battery (13.xV?) I'm pretty sure it will charge the battery at around 14V.
I'd just try it and see.
The more I think about it, the more I think about Einsteins conservation of energy law. I think the energy is going to be the same, no matter what I do. Doesn't matter if I give "x" amps at "x" volts or "y" amps at "y" volts. The energy I am putting into the battery will be the same. So Einstein says.
That is by no means a general principle. It only works if the Power remains the same and there is no reason to suspect that it applies when a non-linear device like a solar cell is involved.
There will always be an optimum condition for running a PV charger and you can buy devices (MPPT) that will try to get the best Power transfer into a load under all lighting conditions. For a small installation, the cheaper solution is just to use more area of cells - and the cheaper MPPT units are pretty poor, I've heard.
Sopiecentaur had the right answer. But if your panels are small enough, you do not need the expense. Charge controllers extract maximum energy, but their primary purpose is to prevent damage to the battery by overcharging.
If the charging current is 1 amp or less, it is considered a trickle charge. You can charge at that rate forever without damaging the battery. (You can stretch that to 1.5 or 2 amps). Just connect the panel to the battery directly, and don't worry.
If the current is in the range 2-7 amps, then an inexpensive pulse width modulator controller is best. They simply limit current to prevent battery voltage from ever exceeding 13.8 volts. Find some here.
For currents higher than 7 amps, buy a charge controller big enough for your needs.
The most expensive MPPT controlers not only protect, but optimize. But the biggest gains are with large installations and with voltages 48v or higher. For smaller or lower voltage applications, the extra expense of MPPT is not justified.
Bottom line, read the nameplate on your panel. Divide the watt rating by 13 to get currrent.
  • · Replies 31 ·
  • · Replies 153 ·
18K
