High School Question about a vacuum ejector (vacuum pump using the Venturi effect)
A vacuum ejector's performance is directly affected by atmospheric pressure; as pressure decreases, its suction capability diminishes. At higher altitudes, like 20,000 feet, the atmospheric pressure is significantly lower, resulting in reduced effectiveness of suction cups. The principle of conservation of energy applies, indicating that a decrease in pressure leads to a decrease in total energy and suction power. The mechanism relies on atmospheric pressure pushing against the suction cup rather than the cup itself creating a vacuum. Overall, less working pressure equates to less useful vacuum generation.
nicolas1409
TL;DR
What happens to a vacuum ejector if the pressure drops
I have a vacuum ejector and with a suction cup that drops items. think maybe it could be a pressure drop. but what happens if a vacuum ejector gets less pressure, does it suck less? know it's something with bernoulis
If the pressure decreases, the total energy must decrease and thereby the principle of conservation of energy can be used
If you mean "does a suction cup suck less when atmospheric pressure decreases" then yes.
If you're at seal level you have ~14psi pushing against the cup from the outside. At 20,000 feet altitude, less than that : ~7psi.
Technically of course the suction cup isn't sucking, the atmosphere is pushing.
A vacuum ejector run on compressed air and I wonder if it falls. and the explanation for that.
Likes Dullard, nicolas1409, gmax137 and 1 other person
Thank you very much for the warm welcome
I'm still having trouble finding a spicefict place it says it. After looking several times.
"Yes, less working pressure leads to less useful vacuum."
Not just correct, but precisely correct. Kudos, sir! (color emphasis mine).
  • · Replies 16 ·
