Question about cornstarch/ non Newtonain fluid
  • Thread starter Thread starter superaznnerd
    Fluid
The discussion centers on measuring the compressive ability of substances, specifically using Hooke's law (F = -kx) and the spring constant (k). Participants explore how different materials, like trampolines and beds, respond to compression, highlighting the importance of material properties. There is a specific inquiry about the force constant (k) of cooking cornstarch, a non-Newtonian fluid, and suggestions for experimental methods to determine it. The conversation also touches on Young's modulus as a relevant property for understanding material deformation. Overall, the thread emphasizes the need for experimental data to quantify the compressive behavior of various materials.
superaznnerd
How do you measure the ability of a substance to take compression? Do you use the force constant (k) of Hooke's law? F = -kx?
For example, what propoerty correlates with a trampoline's ability to take compression better than a bed?
Also, where can I find the force constant (k) of everyday items? More specificlly, I am looking for the force constant (k) of cooking corn starch, a non Newtonain fluid? Does anyone know it?
k is a spring constant , k is measured by doing an experiment , putting a weight on and seeing how much it stretches but maybe you can see how mush cornstarch gives , by psi/distance and do some testing
Are you thinking of Young's modulus?
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
