Question about differential equations?(Nonhomogeneous equation)
  • Thread starter Thread starter hard_assteel
    Differential
3 replies · 2K views
hard_assteel
I am having trouble with the following
y''+7y'+10y=18te^(5t)
yp(t)=Ae^(2t)+Bte^(5t)
yp'(t)=5Ae^(5t)+Be^(5t)+5Bte^(5t)
yp''(t)=25Ae^(5t)+5Be^(5t)+5Be^(5t)+25...
A=(-4.37/70), B=(18/70)
i plugged into yp and got
(-4.37/70)e^(2t)+(18/70)te^(2t)
But it was wrong
Thank You
Discussion
Why did you try Ae^(2t) as a part of your particular solution?
The solutions to the homogeneous equation are c1e^(-2t) and c2e^(-5t), and this can be seen by looking at the characteristic equation for the homogeneous differential equation. For the nonhomogeneous equation, any particular solution must be of the form Ae^(5t) + Bte^(5t).
oops sorry, that was just a typo, i meant to put e^(5t) not e^(2t)
OK, I didn't catch what you had in the following lines. That particular solution should work, but check your work to make sure that you did the derivatives correctly, and don't use approximate values (e.g., -4.37/70 for A).
Also, you apparently substituted your values for A and B into the incorrect particular solution.
