How Much Space Material is Needed to Alter Earth's Gravity?
  • Thread starter mapper
  • Tags
    Gravity
In summary, the conversation discusses the possibility of a measurable change in Earth's gravity caused by material from space. The participants question how much material would be needed and how long it would take for this change to occur. They also consider the impact of a 50 kilometer object sticking to the Earth and how it would affect the mass and gravity. Calculations are suggested to determine the necessary mass to produce a measurable variation in gravity. The conversation ends with a question directed at Daniel.
mapper
123
Apparently we get tons and tons of material dumped yearly onto our planet from space. Just wondering how much would be necessary to affect Earth's gravity so we can see a measurable change and how long that could take? How would you go about figuring/calculating this? Would it be millions of years or longer?
So say a 50 kilometer object were to pound into the earth, although we would surely all perish would something like this effect Earth's gravity to the point of being measurable?
Let's say it "sticks" to the Earth,so that total mass is M_{initial,Earth}+M_{object}.Compute the mass of this object,as to produce a variation of "<g>" to let's say 6-th decimal.Assume mean radius to be the same b4 & after the impact.
Daniel.
It is true that Earth receives a significant amount of material from space every year, in the form of meteoroids and other debris. However, the amount of material needed to have a measurable impact on Earth's gravity is incredibly large and would likely take millions or even billions of years to accumulate.
To calculate the potential change in Earth's gravity, we would need to know the mass and velocity of the object colliding with Earth. Using this information, we could apply the law of conservation of momentum to determine the change in Earth's velocity and therefore its gravitational pull.
In the scenario you mentioned, a 50 kilometer object colliding with Earth would certainly have a significant impact and could potentially alter Earth's gravity. However, it is important to note that the effect would likely be minimal and would not be measurable by humans. The Earth is an incredibly massive object, with a gravitational pull that is already very strong. It would take a much larger and more powerful force to significantly alter its gravity.
In summary, while it is possible for a large object colliding with Earth to affect its gravity, the amount of material needed for a measurable change is immense and would likely take an incredibly long time to accumulate. It is also important to consider the laws of physics and the immense size and mass of Earth when calculating the potential impact of such events.
Related to How Much Space Material is Needed to Alter Earth's Gravity?
1. How does Earth's gravity work?
Earth's gravity is a force that pulls objects towards its center. This is due to the mass of the Earth, which creates a gravitational field that affects all objects on or near its surface.
2. What is the strength of Earth's gravity?
The strength of Earth's gravity is 9.8 meters per second squared (m/s^2). This means that for every second an object falls, its speed will increase by 9.8 meters per second.
3. Does Earth's gravity vary in different locations?
Yes, Earth's gravity can vary slightly in different locations due to variations in the Earth's shape, density, and rotation. However, these differences are very small and not noticeable to humans.
4. How does Earth's gravity affect objects in space?
Earth's gravity affects objects in space by pulling them towards its center. This is what keeps the moon in orbit around the Earth and what allows satellites to stay in orbit around the Earth.
5. Can Earth's gravity change over time?
Yes, Earth's gravity can change over time due to factors such as the movement of tectonic plates, changes in the Earth's rotation, and the melting of glaciers. However, these changes are very small and not noticeable to humans.
  • General Discussion
  • New Member Introductions
