Question about energy (explosions)
To determine the energy needed to destroy an object at a specific distance from an explosion, one can use the concept of energy dispersion over a spherical surface. The energy released by the explosion spreads uniformly in all directions, allowing for calculations of energy per square meter at a given radius. The inverse-square law is relevant here, as it states that the intensity of energy decreases with the square of the distance from the source. For example, if the energy needed to destroy a planet is known, one can calculate the required initial explosion energy based on its distance from the blast. Understanding these principles simplifies the calculations involved in assessing the impact of explosive events.
nicholas0211510
I'm new to physics I tried doing some research but I can't seem to fully grasp the concept.
My question is, how would one find how much energy is needed to destroy a object a select distence away from the blast
For example if a star when super nova and had a x amount of joules, and let's say a planet was 10 AU away, and that planet was Earth and the energy needed to destroy it was 2×10^32 joules
How would you calculate the intensity of the intial explosion to be able to still destroy the planet at that distance?
I believe it was square inversed law but I'm not sure could someone help me out?
Hi nicholas0211510. :welcome:
If the energy spreads out uniformly in all directions, then imagine a sphere totally enclosing the exploding body. At whatever distance out from the centre of the exploding body you choose to draw the enclosing sphere, all that liberated energy will be spread over the surface of the sphere and you can calculate a Joules/m2 figure for that radius out. Do this calculation for whatever distance away the planet is located, and see whether you can figure out the remaining step.
Likes nicholas0211510
Thank you, I didn't imagin it would be as simple as that
I figured you would need to find a lot of variables like I was reading about the square inversed law, but i guess that formula does not associate with the topic at all?
The inverse-square law certainly does apply: if you double the radius of the enclosing sphere, the Joules/m2 changes by a factor of 1/4.
I see, I appreciate the help
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
