Question about integral and Abs function
  • Context: Undergrad
  • Thread starter Thread starter njama
    Function Integral
4 replies · 3K views
njama
Hello!
I want to find
[tex]\int_{0}^{2}{|2x-3|}[/tex]
I know the method for separating the integral on two integrals, but I want to try second method.
I know that
[tex]\int_{0}^{2}{|2x-3|}=\frac{|2x-3|(x-3)x}{2x-3}|_{0}^{2}[/tex]
But in this case I got F(2)-F(0)=-2 and on the first method 5/2.
Why the second method does not work?
Thanks in advance.
CompuChip said:
What makes you think that the last equation is true?
I don't see where the x(x - 3) comes from, and how taking the derivative of sgn(2x-3) x (x - 3) is |2x - 3| :S
It is.
Let |2x-3|=[itex]\sqrt{(2x-3)^2}[/itex]
[tex]\frac{\sqrt{(2x-3)^2}(x-3)x}{2x-3}[/tex]
Now taking the derivative:
[tex]\frac{(\sqrt{(2x-3)^2}(x-3)x)'*(2x-3) - \sqrt{(2x-3)^2}(x-3)x*(2x-3)'}}{(2x-3)^2}[/tex]
Also you can check it by first
x>= 3/2
[tex](x-3)x=x^2 -3x[/tex]
derivative:
[tex]2x-3[/tex]
Now
x< 3/2
[tex]-(x-3)x=-x^2+3x[/tex]
derivative:
[tex]-2x+3=-(2x-3)[/tex]
This is a lot work to do here, so I check it again with Mathematica 5.0 and it is true. But still can't see the problem.
njama said:
Hello!
I want to find
I know that
Thanks in advance.
You can't ignore the fact that there is a discontinuity at x = 3/2. The proper computation is
[tex]\left.\mbox{sgn}(2x-3)(x-3)x\right|^{2}_{3/2^+} + \left.\mbox{sgn}(2x-3)(x-3)x\right|^{3/2^-}_{0},[/tex]
where 3/2^+ means infinitesimally above 3/2 and 3/2^- means infinitesimally below 3/2, such that in the first term sgn(2*x-3) = 1, while in the second it is -1. You then get
[itex]-2 - (-3/2)(3/2) - ((-3/2)(3/2) - 0) = 5/2[/itex], which is your desired result.
Thanks for the reply. I think I understand.
[tex]A_1(x)=(x-3)x[/tex] when x>=3/2
and
[tex]A_2(x)=-x(x-3)[/tex] when x<3/2
Where A1(x) and A2(x) represent the area of the interval [0,x]
But if I want to find the area on the interval [0,2]
Now I find the area of [0,3/2] + (area [0,2] - area [0, 3/2])
First I must find A2(3/2)+(A1(2) - A2(3/2))=A1(2)
