Question about introductory vectors.
6 replies · 2K views
icesalmon
Given ||v|| = 6 and u = < 0,3 >
find the vector v with the given magnitude and the same direction as u
u = v / || v ||
It seems simple enough, substitute the appropriate numbers into the equation and solve for v so < 0,3 > = v / 6 so v = 6 * < 0,3 > or v = < 0,18 >. The answer is that v = < 0,6 >. I'm really not sure what is going on.
if u = < 0,3 > it's direction, magnitude, or size is 3
< 0,6 > are the components of a vector with magnitude 6. Oh, and because it's direction is the same all you have to change is it's magnitude, okay I understand.
That doesn't answer why I didn't get v = < 0,6 > using the above equation.
What you're saying makes sense, but I don't know if it's that easy with the following problems.
Its magnitude or size is 3, but its direction is <0, 1>. To get this, multiply the vector by the reciprocal of the magnitude. The direction of a vector v is the unit vector (1/|v|) v.
Okay, so I need to re-read this section before I put a pencil to paper. I clearly don't have any sort of grasp for these things. Thanks for your help, i'll post back if I have any further questions.
To find a vector of magnitude "x" in the direction of vector [itex]\vec{v}[/itex], you have to multiply a unit vector in that direction by x. A unit vector in the same direction as v is given by
[tex]\frac{\vec{v}}{|\vec{v}|}[/tex]
In this particular problem, [itex]\vec{v}= <0, 3>[/itex], which has length 3, so a unit vector in that direction is
[tex]\frac{<0, 3>}{3}= <0, 1>[/tex]
A vector of length 6 in the direction of [itex]\vec{v}\itex] is<br /> [tex]6\frac{<0, 3>}{3}= 6<0, 1>= <0, 6>[/tex][/itex]
okay, I understand the problem now. A lot more than I did before, it's not difficult, and maybe I should have posted it in the pre-calculus section. But this is where we started off in my Calculus II course. Thanks HallsofIvy.
