Understanding Momentum: Comparing Mack Trucks and Small Trucks
  • Thread starter Thread starter bower5932
    Momentum
Momentum is defined as the product of mass and velocity (P = mv). In the scenario presented, a stationary Mack truck has zero momentum due to its velocity being zero, while a moving small truck has positive momentum. Therefore, the small truck has more momentum than the stationary Mack truck. The confusion arises from misunderstanding the impact of velocity on momentum. The discussion confirms that the initial assessment regarding momentum calculations is correct.
bower5932
I'm trying to help my high school kid solve some momentum problems, and one of us must be missing something simple. The question is "What has more momentum a Mack truck (ie, very large object) that is still or a small truck that is moving?" I thought that momentum=mass*velocity. If this is the case, then the Mack truck would have a 0 and the small truck would have a positive number. However, my kid tells me the answer is the Mack truck. Am I missing something?
Thanks in advance.
Don't think so.
You're right.
P=mv
momentum
your are correct
movementum is defined as
P = mv
where P is linear movementum, m is mass of object and v is velocity.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
