Question about n rotating parallel cylinders
In summary, the scenario involves n identical vertical parallel cylinders rotating around their length axes with the same angular velocity, brought together in fixed positions with no slipping. For even n, there is no rotation and all cylinders are at rest. For uneven n, the cylinders end up with contrary velocities, with the absolute value of their angular velocities being 1/n of the initial value. The energy is dissipated through friction and heat, while the momentum remains and the joined figure must still rotate with the original combined angular momentum. The motion of the system is constrained due to friction, preventing any independent spinning of the cylinders.
Prishon
50
There are n vertical identical parallel identical cilinders rotating around their length axes with the same angular velocity. The are somehow fixed wrt to Earth and brought together (on a rail?). After the contact there is no slipping and the cilinders are coupled to their neighbor cilinders. It is easy to see the cilinders end up as follows:
For even n there is no rotation anymore. All cilinders are at rest.
For uneven n the cilinders end up with contrary velocities. If there are n cilinders in contact then the absolute value of their angular velocities will be 1/n of the initial value.
For example, 3 cilinders (assuming their mass and initial angular velocities are 1) end up with angular momentum 1/3 and kinetic energy of 1/9 of the initial value.
But how is the energy dissipated? 1/9 of the momentum and energy are left in the cilinders. The rest of the momentum has flown into Earth. But where has the energy gone. Not into the Earth(well a very small part). Has it gone by friction? But what if the cilinders were toothwheels?
If there are n identical cylinders and each has angular momentum of p, then the total angular momentum (be they apart or brought together) is n*p. That or external torque was applied, but you don't indicate that.
So if two of them are brought together, they'll form a sort of spinning snowmanular-cylinder shape (yes, that's a word now). The energy went away via friction/heat when they touched but the momentum must remain, so the joined figure must still rotate with the original combined angular momentum.
Can you provide a reference or link for "snowmanular"?
The momentum of say 3 cilinders is not the same before and after. In the beginning they all 3 rotate say clocjwise (with omega say 1) and afterwards they rotate with omega 1/3, tbe middle one anti-clickwise, as it must be since they are oushed against one another.
They are pushed together in fixed position wrt to the Earth. Didn't I mention?
This question comes forth if I search the net for that word...:)
So you have three cylinders spinning about their axes that are brought together to touch and look from above like this OOO Correct?
Then because of friction, their surfaces will eventually stop moving relative to each other, correct?
While they are in contact, the angular momentum of the three-cylinder system about the axis of the middle cylinder is conserved because there is no external torque acting on this system about that axis, correct?
If all of the above is correct, what kind of motion do you think the three-cylinder system is going to undergo? Remember, no cylinder can spin independently about its own axis because friction has put a stop to that.
Almost right! But the whole system can' t rotate. That system is fixed wrt to Earth. So momentum is tranferred to the Earth.
See? That's a snowman shape, except rotated on its side. Extend it in 3D and it's a snowmanular cylinder.
Sheesh, you guys need to lighten up.
Oh. That wasn't clear from the OP.
Likes Dale
Three identical cilinders (with fixed axes wrt to Earth) are identically rotating. When brought together (say on a rail) they end up with 1/3 of their initial rotational velocity. The middle one obviously rotating contra the others. They end up with 1/9 of initial momentum and kinetic energy.
Four (or 6,8,10, etc.) end up with zero velocity.
Uneven numbers end up with 1/n velocity.
So long as the cylinders remain counter-rotating and in line, all is OK.
But during the crush, when any three get out of line and form a triangle, the teeth will mesh and those three gears will lock together, then groups of three will lock, and so on.
This is a similar problem to the over-speed failure of a flat, circular disk flywheel breaking into three equal 120° pie-slices. What is the rate of rotation increase of the fragments, each of which has a lower moment of inertia than the original wheel.
But they stay in line always. Their axes are fixed wrt Earth (they can only be brought together on one line; they always stay in line, no trianglez).
1. What is the purpose of rotating parallel cylinders in scientific experiments?
The purpose of rotating parallel cylinders is to study the behavior of fluids and their interactions with solid surfaces. This can provide insights into fluid dynamics, such as turbulence and boundary layer effects, which have important applications in various industries.
2. How does the rotation speed of the cylinders affect the results of the experiment?
The rotation speed of the cylinders can significantly impact the results of the experiment. It can affect the flow patterns, shear stress, and drag forces on the cylinders, which in turn can affect the behavior of the fluid. Therefore, it is important to carefully control and measure the rotation speed in these experiments.
3. Are there any limitations to using rotating parallel cylinders in fluid dynamics research?
Yes, there are some limitations to using rotating parallel cylinders in fluid dynamics research. For example, the results may not accurately represent real-world scenarios due to simplifications and assumptions made in the experimental setup. Additionally, the behavior of fluids can vary depending on the size and shape of the cylinders, so it may not be applicable to all situations.
4. Can rotating parallel cylinders be used to study non-Newtonian fluids?
Yes, rotating parallel cylinders can be used to study non-Newtonian fluids, which have complex flow behavior and do not follow the traditional laws of fluid dynamics. However, the experimental setup may need to be modified to account for the unique properties of these fluids.
5. What are some practical applications of studying rotating parallel cylinders in fluid dynamics?
Studying rotating parallel cylinders has various practical applications, including in the design of turbines, propellers, and other fluid machinery. It can also aid in understanding the flow of blood in blood vessels and the movement of air around aircraft wings. Additionally, it has applications in the development of new materials and coatings that can reduce drag and improve efficiency in various industries.
  • Classical Physics
