Can a Piezo Crystal be Used as a Segmented Actuator for Voltage Measurements?
  • Context: Undergrad
  • Thread starter Thread starter Sturk200
    Crystals Piezo
The discussion centers on the use of piezo crystals as segmented actuators for voltage measurements. Participants confirm that applying pressure to a localized area of a piezo crystal can generate voltage, but the extent of voltage spread across the crystal remains uncertain. The concept of segmented piezo actuators, which utilize multiple electrodes on a single crystal or an array of distinct crystal plates, is highlighted. Notably, a design demonstrated by Binning and Smith in 1986 features a tubular piezo element with segmented electrodes, showcasing practical applications in voltage measurement and movement.
  • Understanding of piezoelectric materials and their properties
  • Familiarity with segmented piezo actuator designs
  • Knowledge of voltage measurement techniques
  • Basic principles of stress and strain in materials
  • Research "segmented piezo actuator" designs and applications
  • Explore voltage measurement techniques using piezoelectric sensors
  • Investigate the work of Binning and Smith on segmented electrodes
  • Examine DIY projects involving piezo elements, such as home-built scanning tunneling microscopes
Engineers, researchers, and hobbyists interested in piezoelectric technology, voltage measurement, and actuator design will benefit from this discussion.
Sturk200
I think I understand the basics of piezo crystals. You apply pressure and the crystal produces a voltage. Conversely, you apply a voltage across the crystal and it deforms.
My question is this: if you were to apply pressure to only a small region of the crystal (if that's possible?), would the voltage be produced only across that region, or would it spread throughout the crystal? What I'm getting at is the idea of hooking up a number of leads to to the surface of a crystal and getting distinct voltage measurements from different physical regions of the object. Is this a thing that happens?
Thanks.
I guess so. This is used the other way around (apply voltage and get movement) to make some neat little piezo actuators. Google "segmented piezo actuator."
Thanks, I just ran a search. I can't tell if "segmented actuator" means they have a number of distinct crystal plates somehow formed into a "segmented" array, or if they are literally taking a single crystal plate and extracting from it information about localized stress/strain. The latter is what I was thinking of. Do you know of any examples of that being successful?
This page may be useful. http://www.piezo.com/tech2intropiezotrans.html
Sturk200 said:
I can't tell if "segmented actuator" means they have a number of distinct crystal plates somehow formed into a "segmented" array...
What I have seen consists of a single tubular piezo element with multiple segmented electrodes around the outside. This design was first demonstrated by Binning and Smith in 1986 (Rev. Sci. Instrum. 57(8), p. 1688, 1986.) I don't know if that's how the commercial ones work but I expect at least some do.
In any event, some enterprising amateurs have even made their own from cheap piezo buzzers. Here's a fascinating little project by someone who made his own STM (scanning tunnelling microscope) using parts from hobby electronics stores.
http://dberard.com/home-built-stm/scan-head/
Check out the fourth photo.
  • · Replies 20 ·
11K
