What is the total combination for choosing 8 questions out of 10?
  • Thread starter Thread starter caesarkim
    Probability
The total number of combinations for choosing 8 questions out of 10 is 45. This is calculated using the formula 10! / (8! * 2!), which accounts for the different ways to leave out 2 questions. Initially, there are 90 combinations when considering the order of selection, but this is adjusted by dividing by 2 to eliminate duplicates. The discussion highlights the use of combinatorial mathematics to solve such problems. Understanding this concept can be facilitated by using a calculator with combination functions.
caesarkim
there are 10 questions. i can choose only exact 8 questions.
what is the total combination?
Mathematics news on Phys.org
45
10!/[(8!)(2!)]
Essentially, you have 10 choices for the first question you leave out, and 9 choices for the second question. This leads to 90 (10x9) combinations. But since it doesn't matter in which order you choose them, you've double counted (ie, you counted #1,#2 ans #2,#1 as different combinations), so divide by 2.
Njorl
Njorl's given you the correct answer, but to expand this is a simple cominatrics question, your calculator will probably have a function that allows you to work it out, combinations are given by:
_nC_r \equiv \left(\begin{array}{c}n\\r\end{array}\right) \equiv \frac{n!}{r!(n-r)!}
that is n different things taken r at a time, so in this case n = 10 and r = 8.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
