Question about resonating in a closed tube.
  • Thread starter Thread starter yokialana
    Closed Tube
To determine the speed of sound in a closed tube resonating at 440 Hz with lengths of 0.195 m and 0.586 m, the relationship between wavelength and tube length must be utilized, specifically that wavelength equals four times the length of the tube. The speed of sound can be calculated using the formula v = f × wavelength, where f is the frequency. Two simultaneous equations can be established from the two lengths provided to solve for the speed of sound. The discussion emphasizes the importance of recognizing that the wavelength can vary based on the harmonic mode of resonance. Ultimately, applying these principles will yield the desired speed of sound calculation.
yokialana
A closed tube resonates at 440 Hz when it is 0.195 m long and 0.586 m long. Determine the speed of sound. How do I do this?
wavelength=4L
v=fw
v= 440 (4L) I'm just not sure how to use both lengths given, can someone help me out?
You do not know that wavelength = 4L.
The wavelength can be 2(L/1), 2(L/2), 2(L/3), 2(L/4), 2(L/5)...etc
You also know that v = f x wavelength. And v does not change
The values you have been given should enable you to write down 2 simultaneous equations from which you can get the answer.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
