Question about speed and vehicles
  • Context: Undergrad
  • Thread starter Thread starter Sundown444
    Speed Vehicles
This discussion centers on the challenges of controlling vehicles, specifically cars and aircraft, at high speeds, such as supersonic velocities. Key factors influencing control include inertia, momentum, and aerodynamic forces. The participants emphasize that while the effort to change speed remains constant regardless of velocity, the sensitivity of controls increases significantly at supersonic speeds due to the dynamics of air resistance and the physics of motion. The conversation also touches on the importance of understanding momentum and the effects of speed on maneuverability.
  • Understanding of Newton's Second Law (F=ma)
  • Basic knowledge of momentum and inertia
  • Familiarity with aerodynamic principles
  • Concept of centripetal force and acceleration
  • Research the effects of aerodynamic drag on supersonic vehicles
  • Study the relationship between speed, momentum, and stopping distance
  • Explore the principles of centripetal acceleration in high-speed maneuvers
  • Investigate the design considerations for high-performance aircraft
Aerospace engineers, automotive engineers, physics students, and anyone interested in the dynamics of high-speed vehicle control and performance.
Sundown444
Say a super fast car is going car is going at twice the speed of sound, an there is an aircraft going at the same speed. Normally, maneuvering and controlling at high speeds (slowing down, speeding up, stopping and changing direction) is very hard. Now, I just want to make sure by asking, what factors make it hard for the car and aircraft to control at high speeds?
Think of Newton's second law. F=ma. Express it as a=F/m. To produce a specific acceleration a you need a specific ratio of F to m. There is no v in that equation. So accelerating/decelerating a fast moving body is no different than for a slow moving body.
Changing or reversing direction is a different question. Why do you think it is more difficult to reverse a body moving at a velocity of 1, compared to reversing a body moving at a velocity of 100?
It's a lot easier to control an aircraft at supersopinic speed because air does not have solid objects and turns to deal with.
While it's not impossible for a car on the ground to go that speed, finding a suitable place to do that without a disaster is not easy.
What I am asking is what properties and aspects that affect movement affect high speed maneuvering? Kinetic energy? Momentum? Inertia? And anything else?
Not sure. You know why?
Reversing a body with speed 1 means a net speed change of 2. (changing speed +1 to -1 is a net change of 2)
Reversing a body with speed 100 means a net speed change of 200.
Could you go into more detail about that, please? And what about for changing direction rather than reversing it?
Let's start with you. What have you studied about physics and mechanics? I don't want to give answers you don't understand.
The same physics applies both to land vehicles and aircraft.
In military scenarios and games aircraft are highly maneuverable units, but not by themselves able to capture territory.
I do understand some physics. Like Centripetal Force, mass times velocity squared over radius of turn. Need I say more?
You were asking what sort of factors need to be considered for designing a supersonic vehicle?
No, just factors that make it hard to control supersonic vehicles.
Sundown444 said:
Need I say more?
Yes, I said 1+1=2 and you asked me to elaborate. Do you not understand that?
I knew that. That wasn't what I was asking about. I meant what you meant in net speed change? I thought you meant net unbalanced force or something, but I could be wrong. I heard of net unbalanced force, but not net speed change.
Now I get what you mean by net speed change. So, is inertia the main factor as to why the vehicles would be hard to control? What about friction and aerodynamics?
It's not that hard but flight controls become hugely more sensitive at supersonic speed and a few millimeters of change are important.
At subsonic speed, typically passenger aircraft say, a few centimeters movement of a wing surface is sufficient for control
At subsonic speed, typically passenger aircraft say, a few centimeters movement of flight of control surface is sufficient for control
So why do the controls become more sensitive at supersonic speeds?
I'm no expert, but I think the answer is that a craft moving at supersonic speed is now facing head on collision with air molecules,
There no longer is any buffer of compressed air ahead of it, well not as much,
I see.
So what about inertia and friction? How do those affect control of such vehicles at high speeds?
As far as I know inertia does not enter into it,
friction does increase with speed though, I think that contributed to commercial SSTs being uneconomic (cool idea though)
I believe you mean air resistance. I meant ground friction.
Your original question was for car or airplane, so I assume you are not asking about aerodynamics.
Not true. The amount of speed change might be larger, but the effort to change speed, or accelerate are the same at any speed. That's why I pointed you to the equation F=ma in post #2. F=ma does not change with speed. Do you understand that or not?
anorlunda said:
Your original question was for car or airplane, so I assume you are not asking about aerodynamics.Not true. The amount of speed change might be larger, but the effort to change speed, or accelerate are the same at any speed. That's why I pointed you to the equation F=ma in post #2. F=ma does not change with speed. Do you understand that or not?
I understand that. But forget I said the very hard part. I just want to know what factors affect control and maneuvering in vehicles at high speed, whether it be inertia or some other things. That is all I am asking. I wasn't asking about inertia alone, you know.
Many factors affect the manoeuvring rates of aircraft . In the limit though it comes down to power to weight ratio , structural strength and stability .
For any actual aircraft design there will be a set of performance charts defining the acceptable combinations of the several different factors affecting specific flight manoeuvres .
Just note though that with modern high performance aircraft such as fighters and stunt specials the limit on manoeuvring rates is usually set by the maximum g level which the pilot can tolerate rather than by any limitations of the actual aircraft design .
I still don't understand the question. Please clarify. Are you asking about airplanes in the air, or about any fast moving object whether in air or space?
Inertia does not change with speed.
I knew that, but I wasn't asking about just inertia.
Ans yes, I meant air and space.
  • · Replies 16 ·
  • · Replies 18 ·
  • · Replies 169 ·
15K
  • · Replies 17 ·
  • · Replies 32 ·
