Question about spirngs their force
  • Thread starter Thread starter AFG34
    Force
When a spring is compressed between two boxes of different masses and released, it exerts equal and opposite forces on both boxes, in accordance with Newton's Third Law. However, the resulting accelerations of the boxes will differ due to their varying masses, meaning that while the force is the same, the effect of that force is mass-dependent. An experiment using a spring scale can illustrate this principle by showing how the force readings change with different masses. The discussion emphasizes the relationship between force, mass, and acceleration. Understanding these dynamics is crucial for grasping fundamental physics concepts.
AFG34
if there is a spring between two boxes of different masses, and the spring is compressed, with energy stored, then if the i let go of the boxes at exactly the same time, will the spring exert the same amount of force on both of the boxes? or does the force it exerts on the boxes is mass Dependant?
Think Newton's Third Law.
The force of the spring will be the same on both boxes, equal and opposite. Remember that the accelerations will still be different though.
yes, the accelerations are mass Dependant.
Thank You.
This is an easy experiment to try. Hook a spring scale onto a spring scale which is hooked onto a big mass (like the earth). Then hang a mass on the lower spring scale. How do the two readings compare to the mass?
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
