Question about the Conservation of Energy
The discussion centers on the application of the conservation of energy to determine the velocity of a cart rolling down a ramp and flying off a table. The user correctly uses the equation mgh1 = mgh2 + 1/2mv2 but struggles with the height values, initially using h1 as 5 meters and h2 as 3 meters. Clarification is provided that the total height should be considered from the ground level, suggesting h1 should be 8 meters if the table is at 3 meters. The user questions whether the release height can be treated as "0" height, indicating a misunderstanding of reference points in energy calculations. The conversation emphasizes the importance of correctly defining height in energy conservation equations.
nicholz
If a cart rolled down a ramp 5 meters high and flew off a a table at 3 meters high, what would its velocity be?
please let me know where i go wrong, i was using the law of conservation of energy
mgh1=mgh2+1/2mv2
mg(h1-h2)=1/2mv2
v=square root of 2g(h1-h2)
where h1=5 and h2=3
i plugged in numbers for the variables and i can't seem to get it to work out. is the equation i came up with correct?
edit: i was thinking that it should come out to the square root of 2gh. would that be right though? can i consider the release height to be the "0" height here?
Yes your equation is correct, though since the ramp is 5m high and then the table is 3m high, shouldn't h1=8m?
