Question about the Speed of Sound
The speed of sound is primarily influenced by the medium through which it travels, including factors like density and temperature. While louder sounds can theoretically travel faster, in practical terms, most sounds are quiet enough that their speed remains relatively constant. The speed of sound varies across different gases and environments, such as water and the atmosphere, and is not a fixed value. Seismologists utilize sound waves to analyze geological layers beneath the Earth's surface. Understanding these principles is essential for grasping the nuances of sound propagation.
Vorde
Operating on what I have been taught (that sound is the vibration of the air and that particles compress, then expand, then bump into others which compress, hence waves), I don't see why louder sound doesn't travel faster than slower sound?
Can anyone help me with this?
It actually does. However, pretty much all sound is quiet enough so that the speed of sound doesn't change very much for any reasonable volume. Extremely loud sound would travel faster than the "speed of sound" though.
Do you happen to know on what basis the speed of sound as defined is? Is it just the average speed or is it the precise speed of a particular sound.
ohhh yeah ??
do you have any references for that please ?
everything I have ever read indicates that the only thing that affects the speed of sound is the medium that it traveling through.
Dave
its speed is not constant, for the reason I stated in my last post.
its different in different pure gasses, in water, in the atmosphere and even then depends on the air density and temperature. More dense at the Earth's surface than at say 5km altitude.
it has a different speed through the earth.
Seismologists use sound waves to determine depth, thickness and type of rock layers below the surface of the ground.
a good place to learn some basics is from wikipedia...
http://en.wikipedia.org/wiki/Speed_of_sound
cheers
Dave
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
