Lsos said:
You're right that acceleration exists away from the Earth in both cases. But, when you fall, you start out with a negative velocity, so that when you are finished accelerating away from the earth, you end up with a zero velocity. When you jump, you start out with zero velocity, you accelerate away from the earth, and you end up with positive velocity.
Errr... you can start with 0 velocity, nothing seems to prevent it. That is 0 velocity downward towards Earth's core. 0 velocity is not the same as negative velocity. 0 is non-negative. Sorry to nitpick... I apologize for rudeness.:s
Imagine if you are Felix Baumgartner and balloon stays at constant altitude.Then you jump out of the balloon, or walk out of the balloon rather. Ground vanishes beneath your feet, when you take step outside the cabin of the balloon. Then begins the air drag and gravity effects. Essentially the lift force from balloon, stops at this point indeed.With regards to jumping upwards, from the ground...
Certainly your own mass stays the same during jumping and standing still, on earth.
But when you jump upwards, you basically squat down first (bend your knees)... Then your muscles engage and you are able to jump upwards. Does your weight, change?
Is it simply so that the weight doesn't change? Does there become increased net force towards earth, when you push hard from your bent knees? (increased net force when compared to simply standing still on your legs).
Increased net force toward earth, would mean that there exist equally great counter-force away from the earth? Certainly it feels like your body has more momentum outward from earth, when you jump with the squatting technique...
Weight happens because of gravity, right? Gravity is fundamental force in universe.
But gravity strength, depends on mass? My mass stays the same, Earth mass stays the same, when I jump upwards from earth.
