Question about Third Newton Law
The discussion revolves around the differences in acceleration experienced when a person jumps versus when a person falls to the ground. Participants explore the implications of Newton's third law in these scenarios, examining the forces involved and the resulting motions. The conversation touches on conceptual and technical aspects of physics, particularly relating to forces, acceleration, and the nature of human movement.
  • Some participants note that when jumping, a person exerts a force greater than their weight on the Earth, while in free fall, the force exerted is negligible.
  • Others argue that both jumping and falling involve acceleration away from the Earth, but the initial conditions (velocity) differ, leading to different outcomes in terms of final velocity.
  • A participant suggests that the distinction lies not between jumping and falling, but rather between jumping and landing, emphasizing the role of body mechanics in force absorption.
  • There is a discussion about whether the weight of a person changes during a jump and how the net force towards the Earth is affected by the act of jumping.
  • Some participants highlight that the Earth also experiences a minuscule acceleration away from the jumper, although it is imperceptible due to Earth's massive inertia.
  • One participant raises a hypothetical scenario involving a rigid object to illustrate the forces at play, questioning whether the original question was fully understood.
Participants express differing views on the nature of forces and accelerations involved in jumping versus falling. There is no consensus on the specifics of how these forces compare or the implications of body mechanics during these actions.
Some claims about forces and accelerations depend on assumptions about body mechanics and the definitions of velocity. The discussion does not resolve the nuances of these assumptions.
AlbertE97
If I jump, I accelerate away from Earth.
However, if I drop a human on the ground, he doesn't accelerate away from the Earth.
In both cases the force used on the Earth is about the same, but acceleration away from the Earth exists in one case and doesn't exist in another case. Why so?
(not a homework question but one I thought of myself)(English is my 2nd language)
Only while still in contact with the ground, using your muscles.
It is not.
"It is not."
I understand that they're different. But they're not that much different - both are not negligible and not huge. When you jump, you use your mass + a bit more. When you fall, you use your mass + a bit more.
AlbertE97 said:
"It is not."
No, when you jump your feet push Earth quite hard (with more than your gravitational force), when you fall your feet do not push Earth at all.
Please do not remove your posts, others might have the same question and be happy to find an old thread about it (also via google).
You're right that acceleration exists away from the Earth in both cases. But, when you fall, you start out with a negative velocity, so that when you are finished accelerating away from the earth, you end up with a zero velocity. When you jump, you start out with zero velocity, you accelerate away from the earth, and you end up with positive velocity.
Thanks, Lsos. I think that you have decoded the OP correctly. The distinction is not between jumping and falling. It is between jumping and landing.
Errr... you can start with 0 velocity, nothing seems to prevent it. That is 0 velocity downward towards Earth's core. 0 velocity is not the same as negative velocity. 0 is non-negative. Sorry to nitpick... I apologize for rudeness.:s
Imagine if you are Felix Baumgartner and balloon stays at constant altitude.Then you jump out of the balloon, or walk out of the balloon rather. Ground vanishes beneath your feet, when you take step outside the cabin of the balloon. Then begins the air drag and gravity effects. Essentially the lift force from balloon, stops at this point indeed.With regards to jumping upwards, from the ground...
Certainly your own mass stays the same during jumping and standing still, on earth.
But when you jump upwards, you basically squat down first (bend your knees)... Then your muscles engage and you are able to jump upwards. Does your weight, change?
Is it simply so that the weight doesn't change? Does there become increased net force towards earth, when you push hard from your bent knees? (increased net force when compared to simply standing still on your legs).
Increased net force toward earth, would mean that there exist equally great counter-force away from the earth? Certainly it feels like your body has more momentum outward from earth, when you jump with the squatting technique... :eek:
Weight happens because of gravity, right? Gravity is fundamental force in universe.
But gravity strength, depends on mass? My mass stays the same, Earth mass stays the same, when I jump upwards from earth. ?:)
Technically speaking, the following happens because of Newton's third law.
You accelerate away from earth, AND EARTH accelerate away from YOU.Earth acceleration is really small, though. Because Earth has massive inertia, it is difficult to move Earth from orbit, by humans jumping off from earth.
I understood this question right after putting it on this forum and I erased everything in the post (before anyone posted anything) because there is no 'delete post' button on this forum, but for some reason mods decided to recover the post... just ignore this post...
I'm not sure I follow this question clearly. This seems a very simple matter - a human being is not a rigid object. When a person lands after falling, he/she will absorb the impact with their body, so the force is actually spread through the body. But there is still an upward force. The Earth will tend to move away from you, and you will tend to move away from the earth. It's just not apparent from how your flexible body reacts. If you replace the human body with a rigid object, say a steel ball of same mass and drop onto a hard surface, the object doesn't just stop. There will most definitely be an acceleration away from the earth. Several times until the force is dissipated. Have I misunderstood the question and the forces involved?
Like I said, ignore this post..
I think this thread is done.
  • · Replies 40 ·
  • · Replies 20 ·
  • · Replies 62 ·
  • · Replies 23 ·
  • · Replies 17 ·
  • · Replies 19 ·
