Question about topological manifolds
  • Context: Graduate
  • Thread starter Thread starter Laur
    Manifolds Topological
The discussion revolves around the properties of topological manifolds, specifically whether every continuous and second countable topological manifold has a Euclidean neighborhood around each of its points whose closure equals the whole manifold. The scope includes theoretical aspects and mathematical reasoning related to manifold topology.
  • Some participants question the definition of "equals" in the context of neighborhoods and suggest that it may refer to diffeomorphic neighborhoods.
  • One participant clarifies that they meant a connected manifold and defines "equals" as a neighborhood being dense in the manifold.
  • Another participant points out that while the torus has neighborhoods that are contractible, the whole torus is not, raising questions about the closure of neighborhoods.
  • It is noted that for certain manifolds, such as S^3, T^3, and RP^3, the property may hold, but there is curiosity about potential counterexamples in higher dimensions.
  • A participant introduces the concept of the cut locus in Riemannian manifolds and questions the existence of topological manifolds without handlebody decompositions.
  • Some participants propose a proof idea involving maximal elements in the set of neighborhoods homeomorphic to open balls, suggesting that the closure of such neighborhoods could equal the whole manifold.
  • Concerns are raised about the existence of nested chains of open disks whose union does not cover the entire manifold, using the height function on a torus as an example.
  • There is speculation about the difficulty of showing that a Euclidean neighborhood can always be enlarged to cover the entire manifold, with acknowledgment of complex boundaries.
Participants express differing views on the existence of neighborhoods whose closure equals the whole manifold, with some supporting the idea and others raising counterexamples and challenges. The discussion remains unresolved with multiple competing perspectives.
There are limitations regarding the assumptions made about the manifolds discussed, particularly concerning dimensions and the nature of neighborhoods. The discussion also highlights the complexity of boundaries in relation to Euclidean neighborhoods.
Laur
Does every (continous and second countable) topological manifold have an Euclidean neighbourhood around each of its points whose closure equals the whole manifold?
In what sense do you mean equals? Diffeomorphic?
I would think do. The disjoint union of two manifold is a manifold, right? But any neighborhood has only one connected component but the whole manifold has two.
ETA: Assuming both pieces are of the same dimension.
I meant a manifold that is connected (wrote it as "continuous" by accident).
By "equals", i mean that the neighbourhood is dense in the manifold.
Since the product of two manifolds is a manifold, the torus which is just S1 x S1 is a manifold. But any point has neighborhoods that are contractible, while the whole torus isn't.
But on the torus, every point has a neighbourhood (obtained by removing two orthogonal circles from the torus) whose closure is the whole torus, and which is homeomorphic to the plane (can be "flattened" into a rectangle). That's what I mean. By saying that the neighbourhood is "Euclidean", I mean that it is homeomorphic to R^n.
Obviously it's true for all 1-manifolds and all 2-manifolds. And it's true for S^3, T^3 and RP^3. So a counter-example, if it exists, will be found in dimension 3 or greater in a less common manifolds... I'm quite curious as to what the answer is as well.
I don't know the full answer but for a Riemannian manifold the cut locus works. The manifold is the union of an open cell and its boundary which is the cut locus. For non-smooth manifolds I am not sure. apparently there are toplogical manifolds that do not have handlebody decompositions. They may be candidates.
A sub question would be: if a manifold does have a handle body decomposition is it the union of an open cell and its boundary? This should not be too hard.
Yes!
Consider the set S of all neighbourhoods of a point P which are homeomorphic to the open ball. Try showing that this set has a maximal element (for this you just need to show that the union of a chain in S is again in S). Then that the closure of such a maximal element is the whole manifold.
I haven't worked through the details, but it seems like this argument should work.
gel said:
Yes!
I like that idea
Thinking a bit more about my idea for a proof, the following statement can be proven
- if S is a nonempty collection of subsets of the manifold which are each homeomorphic to Rn, and totally ordered (by inclusion), then the union of S is also homeomorphic to Rn.
This can be done by applying the generalized http://en.wikipedia.org/wiki/Jordan%E2%80%93Sch%C3%B6nflies_theorem" to 'glue' together the different homeomorphisms. It follows that any open subset homeomorphic to Rn is contained in a maximal such subset.
The question of whether such a maximal euclidean neighbourhood has closure equal to the entire manifold still remains.
Interesting. One can have a nested chain of open disks in a manifold whose union does not have the whole manifold as its boundary.
Take the height function on a torus standing on end on the the plane. From the bottom, f(x) < a, for a small enough is a a nested sequence of open disks that has a figure eight as its boundary and leaves out all of the torus above the first saddle point of f.
Well, the unit open ball in Rn is the nested union of the open balls {x:|x|<a} for a < 1. It follows that every Euclidean neighborhood is a nested union of such neighborhoods.
Your example shows that the boundary of such a neighborhood can be a figure of eight, but it isn't maximal.
Showing that a Euclidean neighborhood whose closure isn't the entire manifold can be enlarged sounds difficult. This is because the boundary of the neighbourhood can be very complicated, and fractal-like.
Yeah but showing that you can always cross the boundary to create a larger open ball does not seem easy. Maybe its doesn't always work.
  • · Replies 37 ·
  • · Replies 20 ·
  • · Replies 44 ·
  • · Replies 40 ·
9K
