Question about torque and center of mass
The discussion revolves around the concepts of torque and center of mass in a system consisting of a hollow sphere attached to a rod. Participants explore how to calculate the total torque by considering the individual torques of each object, the direction of motion when torque is applied, and the method for determining the center of mass of the system.
  • One participant describes a setup involving a hollow sphere and a rod, questioning the justification for separating the system to calculate individual torques and summing them for total torque.
  • Another participant suggests that a diagram would clarify the situation, indicating that the description is unclear.
  • Some participants argue that the problem contains irrelevant information and can be simplified to a beam with weights acting at different distances from a pivot.
  • There is a discussion about the nature of torque, including its magnitude and direction, and the conditions for balance in a pivoted system.
  • One participant expresses confusion about detaching the objects to analyze torque, questioning how this relates to the motion of the system if the objects were not connected.
  • Another participant notes that if the system is well balanced, predicting the direction of motion when torque is applied can be difficult, as slight imbalances can lead to a feedback loop affecting the direction of fall.
  • Participants discuss the implications of detaching the sphere and how it would behave differently compared to when it is part of the system.
Participants express varying levels of understanding regarding the justification for separating the objects to analyze torque. There is no consensus on the clarity of the problem or the best approach to solving it, indicating multiple competing views remain.
Some participants mention the potential for confusion due to the complexity of the system and the arrangement of weights, as well as the need for a clear diagram to aid understanding. There are unresolved questions about the assumptions underlying the calculations and the implications of detaching the objects.
This discussion may be of interest to students and enthusiasts of physics, particularly those exploring concepts of torque, center of mass, and mechanical systems involving multiple objects.
MrDickinson
Supposing that we have a hollow sphere of mass m and radius R. Furthermore, suppose that we attach the sphere to a rod of length L and mass M.
Now, suppose we rest the rod-sphere contraption on a pyramid a distance (X+R) from the center of mass of the sphere and a distance [(L/2)-X)] from the center of mass of the rod.
m < M (total mass of the hollow sphere is less than the total mass of the rod)
X, R, L, M, and, m are known
This contraception is such that we can solve for T (torque) by finding the individual torque of each object (T_rod and T_sphere) and adding those torques together.What justification do we have for separating the system, finding the individual T of each object, and summing each T to find the total torque on the system?
Please be very detailed.
Second: How do we know what direction the disc and rod will travel (counter clockwise or clockwise)... the disc will simply fall downward when a torque is applied directly to its center of mass (the contributing force of torque is the force of gravity)...??
Third:
Supposing we wanted to find the center of mass of the system to solve for the total torque on the system, how would this be done?
Thank you to those esteemed individuals who would take the time to help a new such as myself
I think a diagram of this contraption (not contraception) might help people help you. I can only speak for myself, but I found it unclear.
This problem has too much irrelevant information in it .
All you actually have is a beam pivoted at an intermediate point and with an arrangement of weights acting at different distances from the pivot point .
The beam and weights may or may not be in balance depending on the specific arrangement of weights and distances .
If the beam and weights are initially in balance and then an additional weight is added to one side then that side will drop .
This is the basis of the balance calculation :
The product of force times distance is called a torque or a moment . Let's say torque for this discussion .
Torques have magnitude and direction . Direction can be clockwise or anticlockwise . So you can have positive and negative torques .
For a pivoted beam and weights to be in balance the sum of all torques acting on the beam must be zero .
For this simple problem you can say that forces acting are just the weights .
I had to look up the definition of "spurious." The question and constraints do not imply any falsehood.
Let us examine the situation.
I apologize, but auto-correct made a fool of me. In any case, I am constructing a diagram based on the information given and in the steps that said information was given... will post soon
MrDickinson said:
How do we justify this? I do not understand why we are allowed to simply detach the two objects and imagine torque on them? The ball, if detached, would just fall down and would not have any torque related to the rotation of the sphere-rod system?
If you split off part of the rod, then the part not connected to the pivot will just fall down as well. They are connected, however, and so you consider it part of a system. I'm not sure I entirely understand your question, but this is the best way I can answer it.
If it's well balanced, it would be very difficult to predict which way the disc and rod will fall just as it would be difficult to predict which way a well balanced pencil will fall.
The system won't be perfectly symmetrical. If the center of mass is very slightly off to one side, it may begin to fall in that direction. That would cause it to be more imbalanced, thus creating a positive feedback loop.
I hope that answers your questions, but I do find them somewhat confusing.
Whether the ball is attached or not, the torque on the ball exerted about the chosen axis would be the same. (The resulting motion will of course be different if the ball were detached.)
  • · Replies 138 ·
9K
  • · Replies 20 ·
  • · Replies 24 ·
  • · Replies 32 ·
  • · Replies 49 ·
